Results 1 to 3 of 3
Thread: Front suspension geometry
    Jan 2015
    Southern Illinois
    All,
    My Gen I GTM will be primarily for track day use. With that in mind, I am making a few suspension modifications, starting at the front. I will probably get adjustable upper control arms to add caster. For now I mounted the upper control arms under the brackets. I only had to modify 2 brackets each side by moving the little gussets to the outside of the control arm mounting bar. My intent was to increase camber gain. If I set camber to zero, I now have:
    -1 3/8 deg on 1" bump
    -3 deg on 2" bump
    +7/8 deg on 1" droop
    +1 7/8 deg on 2" droop
    Does anyone care to comment on this for a track day car? Too much? Too little? I do not have anti sway bars yet but plan to add.
    Also as others have noted, I need to correct the bump steer. I would welcome recommendations on a good bump steer kit for the front.
    Thanks for your help.
    Ken
    rio rico,az
    Sent you a PM.
    GTM 422, LS6, cam, heads, Mendeola trans
    Jan 2015
    Southern Illinois
    Thank you Jeff.
    I found what appears to be most of a FFR bumpsteer kit in the various boxes that came with my basket (b@$t@rd) case. Sleeves in one box, heim joints loose in a box of fasteners, and tapered shafts in a plastic bag in a different box. It looks like one of the previous builders had all the stuff laid out to build the car and then randomly boxed it up. I think I can find the shims and nylocks at McMaster-Carr. Good thing I like a challenge!
    Ken
