Results 1 to 9 of 9
Thread: Thank you BluePrint Engines!
    Hello folks-
    As some of you know, I recently won the engine in the contest sponsored by the folks at BluePrint Engines. I have been working with the team there to select the right engine for my project. They have been awesome to work with, and have helped me to select a great engine and transmission combination.
    The contest offered a well sorted 302 package that was terrific. However, I have been planning on a 351 based engine from the beginning of my build plan. When I shared that information with the team at BluePrint, they were happy to allow me to upgrade my engine choice to what you see here. What I ended up with was a very, very nice 408W, engine dress kit, and transmission package with the specifications outlined below. Although the engine was delivered a short time ago, I have waited until my boys were able to be with me to make my post about the engine. I really wanted them to see the engine before you all did. I hope you understand!
    I have enclosed a couple of pictures of the engine, and one picture of my boys and me with the engine. They were both home together for Christmas, which is a fairly rare event at our house. I also have posted a link to the engine dyno for those who are interested.
    I am truly overjoyed to have this engine, and am grateful to the folks at BluePrint Engines that made this happen. I can't wait until first start, first go cart, and when she is all done. I know this engine is going to make her scoot! Here are some of the details on the engine package I received:
    Engine specifications:
    Predicted HP & Torque: 425 HP / 455 FT LBS
    Actual HP & Torque: 446 HP / 496 FT LBS
    Compression Ratio: 9.7:1
    Aluminum Heads
    Hypereutectic Pistons
    Roller Cam
    Cast Steel Crank
    Block:
    Hand picked 2 bolt main seasoned 351 Windsor block bored .040 over
    Square and parallel decked
    Align honed main bearing bore
    Rotating assembly:
    New cast steel crankshaft
    New I-beam rods
    Hypereutectic pistons
    Hastings Moly rings
    Rotating assembly balanced to within 2 grams
    Melling high volume oil pump
    Hydraulic roller camshaft
    Cloyes double roller timing chain
    Camshaft degreed for maximum horsepower
    Cylinder Heads:
    BluePrint Performance Aluminum
    Hardened retainers and springs
    2.02 swirl polished intake valves
    1.60 swirl polished exhaust valves
    BP Aluminum Head Part #: HP9008
    Cam Specs:
    Roller
    .543 Intake / .554 Exhaust
    218 Intake / 226 Exhaust duration
    @ .050 - 112 degree lobe separation
    Additional bits:
    Valve covers
    Harmonic balancer
    Water pump
    Air cleaner
    Spark plugs & wires
    Timing cover
    Painted oil pan
    Brass freeze plugs
    Polished Alternator
    Power Steering
    AC compressor
    The transmission package also includes:
    Mcleod Super Street Pro single disk clutch
    Aluminum Bell Housing
    Tremec HD Yoke
    Flywheel “pro-comp”
    VSS Harness
    Reverse light harness
    Pilot bushing
    Clutch kit bolts
    Bell housing to block bolt kit
    Engine guard
    Tuff Stuff starter
    Flywheel bolts
    Here is a link to the dyno video of my engine, so you can see her performance first hand:
    https://www.youtube.com/watch?v=PCC7...ature=youtu.be
    The engine arrived coupled to the transmission with everything in place. They even ground down the parts on the Tremec transmission. It was a complete turnkey set-up, and I could not be happier! I also cannot say enough good things about BluePrint Engines!
    I thought you all might enjoy the update.
    Engine 1 of 5.jpg Engine 2 of 5.jpg engine 3 of 5.jpg engine 4 of 5.jpg Stephen, Brian, and me with engine.jpg
    Many thanks to Kevin AKA Jazzman, for his help educating me (no small task!) so that I can install pictures.
    Congrats. It sounds awesome
    I came sooooo close to going with blue print. If they had offered a 351 other than strokers I would have gone with them. Congrats on the engine!
    I updated the post with pictures. Thank you Kevin -- AKA Jazzman, for his help so that I could upload the pictures. I am not sure they are posted in the forum in the best manner, but they are in there, and you all can now see them. I hope you all enjoy them.
    Thank you for taking the time to look at them!
    You will love that engine. I did a 408 short block this past spring w/ a bit more compression and a bit less cam. I am super happy w/ it although I may upgrade the cam one step.
    Fayetteville WV
    Awesome engine! Nice looking crew too!
    1972 Corvette Stingray 350 c.i. Manual Steering & Brakes
    2003 H-D Softail Deuce 88 c.i. TwinCam
    Gen 3 Coupe Dreamer
    Looks great Steve. Congrats.
    I see the dog is trying to work his way into the photo credits as well. Great you could have your boys there to see it.
    Kearney Nebraska
    Congrats! That is going be an awesome engine in your car. I have a feeling the money you saved is going to be spent on replacing rear tires I helped put it in the crate before we shipped it to you. Beautiful Engine.
    Just an FYI for anyone interested in a BluePrint Engines 351 based FFR package; we are currently looking at putting one together. Stay tuned.
    Serial #9158
    Very cool. They did me right on my 347 as well.
