I just measured the Baer kit I have and it includes 7/8" of spacers. I'm assuming that is all that will fit, while still having the nut engage.
Retro: I know you drilled your spindles out, but do you know if the pinto kit taper bolt will fit in the taper of the Subaru spindles, by chance? Is the aluminum adapter you used the threaded tube connecting the rod end to the tie rod? If you didn't use the taper bolt or the tube nut, it would seem all you used from the kit was the rod-end and spacers no? Might just be cheaper to build your own kit?
