The chassis number is located on the square tube near where the steering wheel pillow bearing will mount in the driver's cockpit. My body also had a crack, mine in the rear driver's wheel well. I asked the body gurus (the Jeffs) and was told it's not uncommon and not a big deal. It will have to be addressed during body work by glassing over it and blending it in. The POL does have some random things on it at times. As was mentioned above, the COO will come as the POL winds down. As to the wheels, this is a really silly question, so don't take it personally: did you order the wheels at the same time as the kit? They are not included with the kit. If you did order them, definitely give them a call. I think they used to be drop-shipped from the manufacturer (if I'm not totally senile); not sure if that is still the case, but it might explain why you didn't get them with your FFR order.
--Nathan
