Results 1 to 1 of 1
Thread: Ultra Thermostat Housing Assy Sale Cobra Earl
    Banned
    TD Motion has put together a complete Thermostat Housing Assembly Kit part of it derives from the lower Cobra Earl Lower Housing. As some of you may know Earl no longer sells to the public due to health issues but we still have available.
    The small block Fords have a lot of issues with getting Air Trapped and not allowing the Air to "Burp" from the Cooling system. Leading to hot spots and fooling the cooling system into thinking its full. This Housing assy will release all the air out of the cooling system. Runs more $$ than a cheap chrome plated steel housing that often leak and peel. This Assembly looks pretty cool under the Hood to Boot!!
    For more details please check out these Two Links
    https://www.tdmotion.com/product/427...t-housing-kit/
    https://www.tdmotion.com/product/spe...ostat-housing/
    "Ultra Billet Aluminum Thermostat Housing Assy"
    Includes:
    Cobra Early Thermostat Housing
    180 Degree Thermostat
    Gasket
    Hardware
    Mid Housing with the 1.5 Radiator hose outlet,
    Fill Neck
    Billet Aluminum 16lbs Radiator Cap.
    TD Motion is the Parts Division of Engine Factory BTW.
