Awesome. Thanks again, Frank. I made a Google Docs (here) with all of this information. I posted it in its own thread, too. Should be a good resource for all of this suspension crap. Any more that you have that I'm missing?
Awesome. Thanks again, Frank. I made a Google Docs (here) with all of this information. I posted it in its own thread, too. Should be a good resource for all of this suspension crap. Any more that you have that I'm missing?184 on the big nut yes.
What I have gathered for the Front suspension with Alu LCAs and Wilwood Big Brake kit is this:
Front Suspension/rack
Transverse bushing nut 140ft-lbs
Transverse bolts to frame 184ft-lbs
Crossmember bolt to frame 70ft-lbs
Black transverse pin bolts 114ft-lbs
Tie-rod end nut to spindle 20ft-lbs
IFS bracket to spindle upper bolt 129ft-lbs
IFS bracket to spindle lower bolt 129ft-lbs
LCA ball joint end to spindle 37ft-lbs
Backplate to spindle 20ft-lbs
Wilwood Big Caliper kit bolts to spindle 47ft-lbs with Red Loctite
A-arms to frame bolts 100-110ft-lbs
A-arms pivot bolts 60ft-lbs
A-arm ball joint bracket to spindle 129ft-lbss
Axle nut to hub 162ft-lbss
Steering rack to frame 44ft-lbss
Steering joint to rack 17ft-lbss
