Results 1 to 2 of 2
Thread: Dynamat
    ohio
    Dynamat
    i put down all aluminium and i am looking to cover it with Dynamat, i wanted to see if others who had done this previously know how much of it to purchase.
    cobra Handler
    I think I used ~35 sq ft. I did not use Dynamat but Summit sells something similar called Hushmat Ultra. It looks and acts pretty much identical (very sticky) and has similar numbers for the damping, heat, and insulation factors.
    WEK.
