Results 1 to 2 of 2
Thread: Tifft type 65 build
    ohio
    Tifft type 65 build
    Hello everyone I've already posted some questions and it may be obvious I'm new at this a little background info about me I live in northern ohio and I own a 1971 oldsmobile 442 and decided I wanted to build a car so I bought this coupe and what I have already done to it is build the front assembly all but two spacers on the bottom of the shocks which were way to big to fit in also did all the aluminium and sorted everything and my next step is the rear irs if i can figure it out any help would be much appreciated!
    Welcome to the forum! As I noted in your IRS thread, you can use the image gallery to embed images in your posts.
    Here's how to change your thread title as you go:
    http://thefactoryfiveforum.com/showt...tle-Guidelines
    And this is how to embed pics using the Image Gallery:
    http://thefactoryfiveforum.com/showt...tures-in-posts
    Can you post pics of the part you are having trouble with?
