Thread: looking for a TKO service Manual
    st. louis, MO
    any help out there.
    found a parts manual and a midshift conversion manual. @ the TTC site
    Mk 3.1 #6945
    st. louis, MO
    http://www.ddperformance.com/PDF/TR-...ice_Manual.pdf
    Got this from Don at D&D
    now i wish i could wave a magic wand and the leak will go AWAY
    Mk 3.1 #6945
    Panhandle, FL
    BigLeo69,
    Are you leaking through the top of the mid-shifter? This was common and there was a fix if that is what is happening.
    Hooked
    st. louis, MO
    Quote Originally Posted by HookedonFord View Post
    BigLeo69,
    Hooked
    no i come to find out its the top cover, Mike Forte doesn't remove it to put his midshifter conversion on from what i am told
    i put baby powder on the topside passenger side after cleaning it and taking it for a run and it is leaching out the top, hard to say if it coming from anything lower but its definitely in front and it appears to be not in the bellhousing.
    new tranny and go-cart finally and i am at my boiling point...............the top bolts are suppose to be about 22ftlbs and i found the front ones to be loose, maybe i got a tranny built on friday or monday.
    Mk 3.1 #6945
    Panhandle, FL
    BigLeo69,
    I found this old post - http://www.ffcars.com/forums/17-fact...ease-help.html and there is video about what i was referring to. I have my TKO out right now, so I think I will check the torque on all the bolts. I hope you get your TKO all sealed up. good night
    st. louis, MO
    Unhappy i guess tomorrow another phone call
    BigLeo69,
    talked to Mike last week said he was sending me a part still no response on shipping, the other thing on that thread it could be is the vent plug may have sealer on it and keeping it from venting correctly, somethin i learned from a friend.
    new part sits for about a year and u get it in and it leaks.....thats BS
    tremec should stand up for parts and Mike should respond to help with no delay, my brother told me to ship it back.
    90 day warranty, but u think a company that supplies us guys with parts to build knows we don't put it in right away, we need it for the build. so an easy 90 day warranty.
    almost like a taillight warranty.
    starting to get me Irish up
    make sure u check the torque sequence on those bolts its in the manual i posted.
    Mk 3.1 #6945
    Fort Huachuca, Sierra Vista, AZ
    Sorry about your luck brother. I have the webpage for that tko manual, thank you. Let us (me) know when and how you fixed the problem. Once again, good luck.
    Owner MK4 7642RD, 393 stroker, Gordon Levy Super Alloy T5, HDX Clutch, Moser 3.31 3-link with disc brakes, 17" Bullit wheels, NT05's, Seat heaters donated by WarmSeats.com, door panels donated by Herbs Door panels.
    Panhandle, FL
    Post TKO service manual
    Another site for the TR-3550 & TKO service manual
    http://www.ttcautomotive.com/english...ice_Manual.pdf
    Panhandle, FL
    Also, mid-shift conversion disassembly and assembly instructions
    http://www.ttcautomotive.com/english...080107_133.pdf
