Results 1 to 2 of 2
Thread: Axle Clamp Bracket Bottom Bolt Too Short
    San Jose, CA
    The 2" bolt that attaches the the axle clamp bracket to the flange on the housing is a little too short for the nut to engage the nylon lock. So it looks like we need a longer bolt. We found 2 1/2" grade 8 bolts but the original appears to be alloy steel. Would this be a suitable substitute or should we find the alloy steel one to replace it?
    Thanks in advance.
    wallace18's Avatar
    Trenton, Florida
    You should be fine. Make sure you put clamp on evenly. I never had a problem with my two of the 3-links using the FFR bolts.
