OK, so I see a supposedly new 2013 short-block was used. Some don't cool as well as others and you sure don't want to be working with an older "open" block. Same for the heads. Besides port design, valve bowl size and compression, some cool better. I just wonder what you are working with and what kind of head gaskets, etc. were used. There's also porting that can be done on the case's oil passages to help with flow restrictions.
In the number of motors I've torn down I've never seen idler pulleys or tensioners that looked worn out like that, in the video...
Gates makes a blue heavy-duty racing belt. You should go with that when you go back together. I used a Tomei Timing Belt Guide on my last build. About $45-50.
