Does anyone know if the Vintage gauges retain calibration if the battery is disconnected?
The Tach, Speedo, Clock, and Fuel Gauge require calibration. The kit comes with one button/cable assembly that is used to get everything set. Practically thinking, probably only the clock might need tweaked now and then, and the rest should never need attention after the first calibration as long as the calibration is retained if power is lost. Therefore I would leave the cable attached to the clock.
Otherwise, I will make three additional cables mounted on a hidden calibration panel in case the battery is disconnected (which it will be now and then). I know I don't want to have top reach up behind the dash and move the cable from gauge to gauge.
I am betting the calibration is held, but I want to ask just in case.
While I'm posting, has anyone used a common ground for the Vintage gauges as the Autometer gauges use? The Vintage Gauges run two wires to all the sensors, and the Ron Francis Harness is not set up that way. I can accommodate two wires (and probably will) since I've unraveled the RF harness and reconfigured to better fit my layout. However, just curious a to see if anyone else has just used one wire and the chassis ground (assuming the second wire is just a dedicated return ground).
Thx in advance.
) so I'll give you a 100% answer in the spring. But during the driving season, I had the main disconnect off for extended periods on multiple occasions. Usually just a few days at a time, but once for 2-3 weeks. Nothing was ever lost.
