Page 45 of 54 FirstFirst ... 354344454647 ... LastLast
Results 1,761 to 1,800 of 2134
Thread: Plavan's 818R Build Thread
  1. #1761
    Chicago, IL
    You've got to beat that Lotus.
    YES, YES, YES! [Even if it is just on the stopwatch]
    Executive Director
    The Community Garage
  2. #1762
    Wayne Presley's Avatar
    Enterprise Alabama
    That guy in the Caterham just can't drive... He's giving up an easy 2 seconds a lap. Chad, the 911 seems a little loose on corner exit, is it?
  3. #1763
    Clovis, Ca
    It's a little loose, but not too bad. Just like any 911 with torsion bars and a 46 year old suspension design. I like keeping my reflexes trained.
    Thanks- Chad
  4. #1764
    Clovis, Ca
    Everyone check your rod ends.
    During my pre race check of the car, both rear inner rod ends separated....... Great....... ordered new ends, but I may have to press these in and use washers to get me ready for the race.
    Thanks- Chad
  5. #1765
    Chicago, IL
    Aurora rod ends & F.K. Bearings rod ends...these are the goods.
    For me, what was supplied was good for set up and shakedown, but everything is getting replaced when its time to start a season.
    Executive Director
  6. #1766
    Dallas
    This implies that the rod end-spacer design maybe wasn't the most well thought out idea. Maybe a high deflection safety washer would've worked better.
    https://www.pegasusautoracing.com/pr...p?Product=3068
  7. #1767
    Clovis, Ca
    Quote Originally Posted by Mulry View Post
    This implies that the rod end-spacer design maybe wasn't the most well thought out idea. Maybe a high deflection washer & a stack of washers behind would've worked better.
    I checked all the others and they were ok. I will be changing them all this offseason if I still have the car.
    Thanks- Chad
  8. #1768
    Apr 2014
    Shelton, CT
    Wow!!! Glad you caught that.... we'll keep an eye on ours. Is FFR replacing them for you, I hope?
    Tamra
    First autocross 3/29/15
  9. #1769
    Clovis, Ca
    Quote Originally Posted by Tamra View Post
    It would just happen again, I'm going to use better stuff.
    Thanks- Chad
  10. #1770
    Denver, CO
    I don't remember seeing anything like this on my car. Did they upgrade later chassis with another side on that end? Maybe they can just send you the other side that you could weld on your chassis later?
  11. #1771
    Clovis, Ca
    Quote Originally Posted by bbjones121 View Post
    These are the same tubes/rod ends FFR provides. They just did not provide them for my car (it's chassis #44). Its the only way to adjust toe correctly at R height.
    Thanks- Chad
  12. #1772
    Denver, CO
    Oh ok. Well I hope you can figure something out. I am really looking forward to seeing how your car does. By the way, I see the other bracket now. From the pictures it didn't look like the bolt/eye was supported on one side.
  13. #1773
    Clovis, Ca
    This should hold them in for this weekend. Then I will replace them all with quality ends.
    You need (2) Grade 8- 5/8" washers, (4) 16mm regular washers per rod end. I got them from Ace Hardware locally.
    Side note: Somehow I got a hold of some of the crappier two piece rod ends- I'm not sure how I let that slip. You should be fine with the one piece ones that FFR provides since it has much higher lateral loads. Don't make the mistake I did.
    Thanks- Chad
  14. #1774
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Good luck this weekend. Hope those anti-collapse things sorts your issue.
  15. #1775
    Clovis, Ca
    Thanks- I found all sorts of crazy weird things. I disconnected the spintric. I need to talk with the ARE guy. It was not flowing that much oil to the coolers, and instead dumping hot oil in the top of the tank. I disconnected it, and now have great flow to the coolers. It was a trickle with the spintric. I also am running sans vent on the case- total vacuum like Gator. There is no way for hot oil to bypass the coolers and dump into the tank now. It all HAS to go through the coolers.
    The inner spring supports are in the vacuum lines, with heatshields over the headers. Oil pump belt is checked for tension. If the oil is not getting pumped out of the motor, it will stay full and not go out my old case vent to the oil tank.... So here goes nothing!
    Thanks- Chad
  16. #1776
    Good luck Chad,
    if the crank case gets full, you will feel a large drop in power making to the wheels.
    Are you going to the track tomorrow?
  17. #1777
    Clovis, Ca
    Good luck Chad,
    I'll be out there testing a half day on Friday. If it works, I'm racing the weekend.
    Thanks- Chad
  18. #1778
    Bend, Oregon
    Fingers crossed for you!
    I know this is Capt Obvious, but you didn't have the Spintric connected in reverse? No need to reply unless it was!
    Owner: Colonel Red Racing
  19. #1779
    Clovis, Ca
    I triple checked. I had it totally correct. I was scratching my head. That's why I disconnected the return line to see what was going on. Nothing on this car makes sense. haha
    Thanks- Chad
  20. #1780
    Aug 2013
    Santa Rosa CA
    Good luck this weekend, your due.
  21. #1781
    NoVA
    ^Agreed. Good luck
  22. #1782
    Aotearoa (New Zealand)
    all the best chad! we are watching from a world away hoping it all comes together on the day.
    __________________________________________________ _____________
    That man is no fool, who gives what he cannot keep to gain what he cannot lose
  23. #1783
    Jun 2015
    Good luck man!!
  24. #1784
    Clovis, Ca
    Thanks Guys! I really want this thing to work.
    I talked with the Engineer at ARE about the Spintric. He said in my case I had to run the Spintric after the coolers. He apologized for not updating the instructions for cars with long oil line runs or multiple coolers.
    Before I re routed, I rev'd the crap out of the car with the Spintric un hooked. There was foam in the top of the oil tank. I then re routed the lines, made a new one, and hooked up the Spintric. I rev'd that crap out of it again, checked the coolers, checked lines, and looked in the tank....No Foam Everything is working on that front for sure. Good oil flow, and no foam in the tank. Lets just hope my real problem was those darn collapsing scavenge lines. Fingers-crossed
    Thanks- Chad
  25. #1785
    Bowling Green, KY
    Fingers crossed
  26. #1786
    Hindsight's Avatar
    Atlanta
    If it doesn't solve the issue (and I'm hoping it does, believe me), have you given any consideration to going back to a wet sump temporarily, as a tool for testing and elimination?
  27. #1787
    Bend, Oregon
    Are you staying with the sealed up motor and just splitting the air/mist line off the Spintric close to the tank? I am imagining you have just the one line from the DS pump>cooler1>cooler2>Spintric split>DS tank?
    I changed my oil yesterday to mothball my car for the winter. Man that 20W50 racing oil is like cold maple syrup!
  28. #1788
    Enterprise Alabama
    Sgt, you forgot the motor
  29. #1789
    Clovis, Ca
    Yes, all sealed up. I tied the head vents together and Tee'd them to the 3/4 case vent line (No more venting to my oil tank). Just like you did. I bought better, stiffer hose that could take the vacuum for the head and case vents. The old hose would collapse on top of the motor with the new sealed set up. It means the vacuum is working.
    As for the Dry sump routing......Scavenge pan>DS Pump>Cooler1 (Rear)>Cooler2(Front)>Cooler3(Front)>Spintric scavenge in>Spintric Magic> Spintric split (two fittings) to oil tank (oily air) to top of tank with special fitting, Scavenge out (no foamy oil) to middle fitting of oil tank. Then there is the vent to a catch can from the other top oil tank fitting.
    I'm leaving all three oil coolers hooked up this time. Maybe I can get rid of the rear one if everything works as planned.
    I'm using the 15/50 Mobil 1. I am bringing my VR1 20/50 also just in case.
    Thanks- Chad
  30. #1790
    Dallas
    My fingers are crossed for you today, Chad.
    What? This is backwards from the documentation they send with that unit. Hmm. Guess I need to talk to ARE before we do our final setup. That routing is really at odds with the normal plumbing routing (like this: http://barnessystems.com/plumbing-schematics/2732883). I wonder if that's because you're not using a DS Pump with a pressure side? Thx Chad.
    How are you guys connecting the head vents to the case vent? Did you drill/tap the case vent for a fitting or what are you using? Are you just using push-on hose and worm clamps at the factory fitting on the head vent? Given the amount of suction from the dry sump, I wonder if all three of those couldn't just be capped, I can't imagine that the heads are filling with oil enough to overflow to the vents when the dry sump pump is running.
  31. #1791
    Clovis, Ca
    Here goes nothing! Forgot my GoPro housing darn it. I'll grab it tonight if things go well.
    Thanks- Chad
  32. #1792
    Luck!
  33. #1793
    Feb 2014
    Asheville, NC
    Good luck! Can't wait to hear how it goes
  34. #1794
    Clovis, Ca
    Didn't work. Packing it up.
    Thanks- Chad
  35. #1795
    Bend, Oregon
    There's pics over the R thread on oil issues, but the short answer is there are two vents on each head. The rear vents stay connected via the OEM balance system of tubes and hoses to the block vent. It stays oem original.
    The front two vents we teed together, then run the teed line back to the former PCV vent fitting in the block. In my case I used a metal elbow to make the turn down to the PCV vent and tapped a vacuum hose into the elbow connected to a boost/vacuum gauge on my dash.
    The purpose is to keep pressures even between both heads and the block.
    Hope this makes sense!
  36. #1796
    Bend, Oregon
    Quote Originally Posted by c.plavan View Post
    didn't work. Packing it up.
    noooooo!!!!!
  37. #1797
    Mechie3's Avatar
    Indianapolis
    Lame.
    Zero Decibel Motorsports
    Check out my new website!
  38. #1798
    Aug 2013
    Santa Rosa CA
    Sorry Chad, still think you are chasing effect not cause.
  39. #1799
    Feb 2014
    Asheville, NC
    What happened? Same thing?
  40. #1800
    Hindsight's Avatar
    Atlanta
    Ugh, sorry man.
