Headlight issue has been resolved. I found a ground wire on the rear lights and accessories section (GB5) that was not attached properly. As soon as I grounded it, I have both low beams and high beams working.
Lesson learned here is to attach every ground wire on the harness, whether you think you need it or not! I almost deleted the accessory wires and ground wire.
Now I need to sort out the tach and fuel gauge. Both were working, but stopped working just recently. I hope the solution to these are a bit easier to identify!
Thanks for the help everyone! I certainly could not do any of this without your help and input!
