Results 1 to 2 of 2
Thread: Steering Joints
    Steering Joints
    I'm having problems getting the steering joints onto the double D shaft for my 33 Hot Rod. I tried freezing the shaft and heating the U joint, but they won't make up. When I try and force it on slivers of metal are chipping off of the shaft. Also, the bearings are really tight as well. Is there a trick I'm missing?
    TX
    WM
    Fresno, CA
    They are a tight fit, I just worked with them to make sure they were perfectly square and then they would slide on.
    Doug
    Built FFR5196 MKII in 2003, 427w
    Building FFR0058HR, Edlebrock 347-AOD
