Chad, I like the oil tank wrapped in reflective tape, but don't see the point of the header wrap as installed. Remember the three methods of heat transfer: diffusion, convection, radiation. The reflective tape is great for blocking radiant heat from IR sources in the engine bay. The header wrap could act as an insulator to diffusion through the tank mount or an additional convection barrier under the reflective tape, but as it is installed I see it working as a blanket that prevents the reflective tape from doing its job and helping the tank retain heat once it has it.
), but not sure I found the one you are using. And I know you are using great stuff, race proven, so I know for me, on the road, it would be a great choice.
