Page 36 of 54 FirstFirst ... 26343536373846 ... LastLast
Results 1,401 to 1,440 of 2134
Thread: Plavan's 818R Build Thread
  1. #1401
    USA
    Chad, I like the oil tank wrapped in reflective tape, but don't see the point of the header wrap as installed. Remember the three methods of heat transfer: diffusion, convection, radiation. The reflective tape is great for blocking radiant heat from IR sources in the engine bay. The header wrap could act as an insulator to diffusion through the tank mount or an additional convection barrier under the reflective tape, but as it is installed I see it working as a blanket that prevents the reflective tape from doing its job and helping the tank retain heat once it has it.
  2. #1402
    Clovis, Ca
    Where exactly (or what brand) did you get your reflective fiberglass tape from? I found a few similar items on ebay (even one to 1800F if you really need overkill ), but not sure I found the one you are using. And I know you are using great stuff, race proven, so I know for me, on the road, it would be a great choice.
    It was probably the same stuff- 1100 constant, 1800F for a short time. Amazon.com. I ordered coming home from the track on Friday night, they delivered it on Sunday!
    Thanks- Chad
  3. #1403
    Clovis, Ca
    Quote Originally Posted by Aero STI View Post
    Hmmmm. I was wondering that when I was putting it on. I was listening to someone else. I may remove the wrap then.
    Thanks- Chad
  4. #1404
    Denver, CO
    You really need a wrap that has air bubbles/space.
  5. #1405
    Denver, CO
    Suisun City, CA
    Just curious... Have you actually measured the ambient temperature in the engine bay at various points?
    Also, why not build some sort of icebox to surround the oil tank?
    818S - #67 (SOLD IT!)
    Delivered: 18 November 2013
    Go Karted: 29 December 2013
    Finished: NEVER!
  7. #1407
    Jul 2012
    Encinitas, CA
    As mentioned, ideally you want a first layer of insulation with dead air space, this will limit heat transfer via conduction and convection. Then a top reflective layer to limit radiant transfer. The reflective foil doesn't provide much/any thermal resistance, and to be effective at limiting radiant heat it needs to be on top.
  8. #1408
    fasterer and furiouser
    Aug 2012
    Long Island
    Did you put a down payment on a GT4 yet?
  9. #1409
    Clovis, Ca
    Quote Originally Posted by wleehendrick View Post
    Yes, I'm taking off the header wrap and leaving the Fiberglass reflective tape. The fiberglass portion of the tape helps that heat barrier insulation, while the reflective portion says "Get the F away radiant heat". (My Layman terms)
    Thanks- Chad
  10. #1410
    Clovis, Ca
    I would of loved to, but this 818R is draining me dry!
    I might actually sell the Spyder. My wife says we have too many cars...... Then I can go back to restoring the 1972 numbers matching 911 once the darn 818R is working correctly.
    Thanks- Chad
  11. #1411
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Isn't your 818 already faster than a GT4 on the track?
  12. #1412
    Aug 2012
    Long Island
    for the first 6 laps
  13. #1413
    Jul 2012
    Encinitas, CA
    There's no such thing... Just a lack of parking spots!
  14. #1414
    Clovis, Ca
    Bahahahahahaha. So true.
    The race track is supposed to be over 100 degree's this weekend. True test.....
    Thanks- Chad
  15. #1415
    Wayne Presley's Avatar
    Enterprise Alabama
    Chad, where in the oil path are you measuring oil temp?
  16. #1416
    Clovis, Ca
    From the rear port on the engine.
    I can feel engine performance suffer once over 245 degrees. That's when I back off and start cooling it down. Feels like bearing clearance starts getting tight. Scary.
    Thanks- Chad
  17. #1417
    Aug 2013
    Santa Rosa CA
    I wonder if the clearance is the cause and not the result.
  18. #1418
    Clovis, Ca
    Quote Originally Posted by D Clary View Post
    But I can run it for a long time at 220-230 degrees no problem. Once it gets higher, it seems to compound. Maybe I should run a lighter oil than 15w -50. I don't know, but I will know on Friday if any of these fixes will work.
    Thanks- Chad
  19. #1419
    Kirkland, WA
    The engine shop that I use and is used by several Subaru Race teams here in the NW say that the Subaru engines have too tight tolerance and they have to open up the tolerances, this has worked well for the race teams here in the NW especially for the rally teams that are running long durations at high revs, the temps come down quite a bit.
    Tony Nadalin
    2022 SOVREN Championship
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
  20. #1420
    Enterprise Alabama
    So that's after the cooler and into the oil galley correct?
  21. #1421
    Clovis, Ca
    Yes.
    Thanks- Chad
  22. #1422
    Kitchener, ON
    I am curious why you are running 15w-50? I thought that was mostly for older V8's. Did you ever try the spec 0w-20 or 5w-30 synthetic?
    From http://www.bobistheoilguy.com/motor-oil-104/ :
    "I truly believe that oil is much better being too thin than too thick. Over the years we have been going to thinner and thinner oils despite hotter engines with turbos and the like. The tendency is that people figure they need a 40 grade oils but then use a 50 instead. Better thinking is that if you think you need a 40, use a 30 grade oil instead. I firmly believe this based on all I know about oils."
  23. #1423
    Clovis, Ca
    Quote Originally Posted by dirty kurty View Post
    Because Racecar.
    Although I may go 40W
    Thanks- Chad
  24. #1424
    Enterprise Alabama
    You have to consider the oil temps in order to have the right viscosity at normal running conditions in race applications, especially on motors with high bearing loads.
  25. #1425
    Mechie3's Avatar
    Indianapolis
    Fast forward to the 35 second mark. hahaha
    https://www.youtube.com/watch?v=WcQe7xTCXHg
    Zero Decibel Motorsports
    Check out my new website!
  26. #1426
    818 builder
    Exeter R.I
    I did just this from my experience with these engines, the piston clearances are too tight from factory and leaning towards the outer limits of the specs is the way to go to control heat and help preserve ring lands and heads. normal driving there fine, racing no.
  27. #1427
    Leesburg, VA
    Classic
    I thought the factory pistons in the EJ engines were cast and expand less - that's why their piston to bore clearances were so tight. Most people that race swap for forged pistons, which expand more, right? I measured my clearances with forged JE pistons around 0.0035-0.0037 if I recall.
  28. #1428
    818 Junkie...
    Atlanta, GA
    Nice!
    So using what it says on the fill cap and going synthetic is good or bad?
    I do have a case of Joe Gibbs LS30 I could start using on the next oil change.
    818R For Sale!
    818R Sale Thread
    PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
  29. #1429
    Clovis, Ca
    FYI- I have Forged pistons
    I just spent almost a full 45 min talking with Phil @ Element Tuning.
    He made me feel better. He said the factory ECU could be cutting in once I get around 250/260 and pulling timing. He says that could be loss in performance I feel. He says its most likely not an oil/bearing/clearance issue since I cut open my filters and they were perfectly clean.
    Here are a few key "Nuggets" we talked about. (TRACK CARS ONLY)
    1. Do not run a oil under 50wt on the race track in a purpose built track/race car. Especially in my hotter environment (over 100 degrees at the race track this weekend). The oil is like water at the higher temps we see. He suggested Redline 50wt, but the Mobil 1 15/50 is good also.
    2. The oil pressure is the key to the EJ motors- On the track, you do not want to see anything under 60psi- or motor will be going quick (Bearing skimming). Between 70-80psi is ideal.
    3. Dump the OEM subaru oil filters and use a OEM BRZ oil filter (Or Fram Extra Guard). They are a little bigger and should fit fine with stock headers. When they blew 3 motors while racing (before their Dry Sump kit) the regular oil filter did not catch crap. When they had the BRZ oil filter and the motor went, it caught everything.
    4. He says the area I'm pulling my oil temp from on the block is perfectly fine. No issues.
    I'm going to test this Friday before the race (104 degrees!!!), and if I am having major issues, I will have them use my race funds for another future race.
    Hump block off fully compete:
    Thanks- Chad
  30. #1430
    Great information Chad,
    The factory ECU doesn't know the oil temp. Only water temp is an input.
    Is it possible that coolant is also going up?
  31. #1431
    Hindsight's Avatar
    Atlanta
    Thx for sharing the info!
  32. #1432
    Clovis, Ca
    No you are right- he was thinking the ecu might think it is knocking. Coolant is fine.
    Thanks- Chad
  33. #1433
    Bend, Oregon
    Oils
    The "best" oil usually degenerates into an endless discussion. But I'll add a couple of comments about Mobil1.
    A lot of people are haters on Mobil1. A lot of that may stem from the new Mobil1 standard GF-5 oil. What folks miss out on is the same criticisms are true for ALL GF-5 oils. That criticism is the lack of zinc and phosphous. Again, all GF-5 oils have lost their zinc, it's part of the GF-5 standard. I know one turbo rebuilder who swears the lack of zinc in the new GF-5 oils is why he sees so many shaft failures.
    I have used Mobil1 Racing 0W-30. It has a butt load of zinc and phosphorus. It has outstanding high temperature characteristics. It has no detergents because it's the real race stuff you change after every race weekend. Do not use in a DD!
    The downside is the cheapest you will find it is $20 per quart . And it's not at any regular autoparts stores. Amazon is best.
    Based on the above I may go to Mobil1 Racing 0W-50. Same chock full of zinc and phosphorus. Same great full on racing oil as the above. It too is crazy expensive.
    In the meantime I think Mobil1 European Car 0W-40 is a good compromise. Not GF-5. 25% more of zinc and phosphorus. Detergents. Specified by BMW and many other European car makers. And at Walmart it's on sale for $23 in 5 quart jugs. Mobil1 5W-50 is probably even better but it's almost twice as expensive and hard to find, $53 for 6 quart box on Amazon. Still a lot cheaper than the full on Racing oil.
    Here's a pdf summary: https://mobiloil.com/~/media/amer/us...ecs-guide.ashx
    Here's the website with all the extra info: https://mobiloil.com/en/motor-oils/mobil-1
    A little additional info: My Corvette C6 Z06 specifies Mobil1 5W-30 GF-5. However I was at the race track this weekend and talking with a C7 Corvette owner. The C7 still specifies Mobil1 5W-30 for daily driving, but the owners manual now specifies Mobil 1 15W-50 for Track days. "Chevrolet recommends Mobil 1 5W-30 for service-fill oil changes and Mobil 1 15W-50 for track events and competitive driving."
    Last edited by Sgt.Gator; 06-15-2015 at 01:32 PM. Reason: Added info on Corvette and corrected GF for GL
    Owner: Colonel Red Racing
  34. #1434
    Tazio Nuvolari wannabe
    south-central CT
    My experience with my STi track car: I run 5-30 Royal Purple XPR in the spring, when days may not get to 60 and tires have trouble getting up to temp. Otherwise I run 10-40 but I do not track my car in July and August. I agree with Sgt Gator and I hope we do not get into that quagmire of a discussion.
    I have a factory short block with CP fully coated, forged, 8.2:1 compression pistons and 11mm oil pump. 395 WHP/393 TQ, 7,200 red-line @24PSI. This is with the external, K&N HP 3001 filter, Setrab #50-640-7612 (12.99" X 12.20"X 40 row) oil cooler and thermostatic valve. Nine quarts of oil. All this I've mentioned here in the forum quite a bit. It's on its third season and showing no signs of tiring.
    FYI: yesterday's track temp was 77 and my oil and water temps did not get past 200. I hit the rev limiter all the time because Thompson is mostly a third gear track.
    I was just on the phone with Gary of Larry's Auto Machine, AKA Larry's Power" in CT. Kenny Carlson is a respected machinist and Subaru engine builder for them. For my 818R destroker motor they are using close to factory rod and crank tolerances since the engine will only make 270 at the rear wheels of the 818.
    I agree with everything
    Phil @ Element Tuning says about building a big, bad-*** Time Attack motor. Mostly, we are not building those kinds of motors. I will probably stick with the 10-40 oil for this new motor.
    As an aside: Late last year a racing buddy had a long-block built by FlatIrons Tuning in Boulder, CO. It has blow-by like a mo-fo. It's doing OK. Runs like stink (meaning as powerful as mine) on premium pump gas, but he has lots of trouble keeping oil in the motor. He's about to put a KB oil control valve on his car. Got it at the Wicked Big Meet. The bottom line, I think, is that the rings were not gapped properly.
    #2 aside: I am talking to a company that makes heat exchanger piping, similar to home heating
    copper hydronics tubing. I should have a quote shortly for two, 4-1/2 foot lengths of finned, 3/4" aluminum tubing with turbulators. The fins are flat, so that air channeled past the tubes will carry heat away fairly efficiently.
  35. #1435
    Clovis, Ca
    Still getting too hot. Granted it's 100 degrees, I got 11 laps in a single session before I pulled off. I then removed the rear trunk lid. That did not help.
    I'm getting tired of this car.
    Thanks- Chad
  36. #1436
    Mechie3's Avatar
    Indianapolis
    Are you running a built, rebuilt, or straight donor motor?
  37. #1437
    Aug 2013
    Santa Rosa CA
    how hot,oil temp or water? Did you try taking the bell pan off under the motor?
  38. #1438
    Sep 2014
    Dallas, TX
    The guys who rebuilt my motor deleted the oil cooler. I don't remember their reasoning.
    818S Chassis #288 2.5L 323hp
    Ordered: 9/19/14 Received Kit: 11/2/14 First Start: 5/31/15 First Drive: 6/7/15 Registered: 3/10/2016 Completed: 2/10/2017
    Status: Complete Build Thread Sold 9/22/2017
    joshuajach.com
  39. #1439
    Mechie3's Avatar
    Indianapolis
    The cooler is a heater as well. It uses 190f coolant to cool the oil, which is good for a dd but not a race car. It also helps to get oil up to temp faster in a dd.
  40. #1440
    Research Calibrator
    Portland, OR
    Indeed Phil has had a lot of track time with his cars, and has seen most of the major failure areas. Are you datalogging stuff from the ECU when you are on track? If not, that would be a very very good idea... even just logging the knock correction and dynamic advance (plus RPM, abs pressure, etc). One of the keys to keeping EJs alive is to watch for knock events. If you get enough knock to pull the DAM down, you will certainly feel that.
