I was thinking of higher spring rates, as I think they were planning on using a sway bar and we are not. Also the aero puts more of a load on the rear, from some photos particularly Brandons, the rear looked like it squatted at speed, that would raise the splitter and cause an aero push. I was thinking higher rates all around with less front to rear split. Just thinking outloud.
). After about 30' of -12 AN hose, a couple new fittings, additional oil cooler in the front, careful trimming/cutting, big P-clamps, 3" duct hose and ducts (both bumper and cooler).... I can now remove my 25 pound ballast :/ . The car takes around 9- 9.5 qts of oil now. I'll know exactly next full oil change.
