Page 33 of 54 FirstFirst ... 23313233343543 ... LastLast
Results 1,281 to 1,320 of 2134
Thread: Plavan's 818R Build Thread
  1. #1281
    I have been thinking that there would be benefit to an actual race setup/results/experiences thread- Either combined autox & road course, or segregated. We have something like 75 minutes of race-pace autoX time on our car now, though it's still "naked", and we've learned a lot about it in that time.
    -Andrew
    Building 818S/R #297 with Tamra
    08 Mazdaspeed3 | '12 F800R | '97 Miata
  2. #1282
    Aug 2013
    Moscow, Idaho
    818R Front Lower Control Arm, Rear Mount Spacers for Sale?
    Does anyone have for sale some front lower control arm spacers for the 818R? (C.Plavan's November 2013 post # 137 mentions that he had some extras that he could sell.)
    Duncan
  3. #1283
    Clovis, Ca
    Quote Originally Posted by dpalm View Post
    Duncan
    I never made another batch because of the minimum. I'm all out.
    Thanks- Chad
  4. #1284
    Tazio Nuvolari wannabe
    south-central CT
    As to Tamra and Andrew's suggestion I would hope that specifics get put in the "R", discussions area. It is easy for good data to get lost.
    To Chad's effort and your documentation and videos, I commend your effort. Bravo!
    I know full-well how much time and energy goes into taking photos, videos, etc. and editing and publishing. Could be time spent working on the car...
    Still, I am a believer of sharing and helping and that it's good Karma! At 68, I feel like I want to help the youngsters when I can.
    Like Chad, we have learned by the school of hard knocks. He's an explorer.
  5. #1285
    Clovis, Ca
    I made my oil cooler box with Incoming air ducts for the 3" hose. I plan on insulating it with reflective tape. I'll redo the side air intakes once the new side scoops arrive.
    I also have Mechie's bigger rear vent coming. I'm hopeful that will help cool things off also.
    Thanks- Chad
  6. #1286
    Clovis, Ca
    I could not live with myself if I left the "Fun Pool Noodle" Track Hack on. It was a track fix for the radiator to hood air block off. I made a proper aluminum one. Fits great.
    It was the one of many things I did at the track to fix the overheating. However, it was the opening of the bottom aluminum pan louvers and removing a little tape from the splitter that did the trick to cure that problem.
    Thanks- Chad
  7. #1287
    Clovis, Ca
    Say "No" to high intake temps. After trying three different spots (Pre-side scoops), this is the winner. It will have no issues sucking in cold air.
    Thanks- Chad
  8. #1288
    Wayne Presley's Avatar
    Enterprise Alabama
    you're going to have to fully sealed that into the engine compartment as you want no flame path between you and the motor
  9. #1289
    818 Junkie...
    Atlanta, GA
    Nice!
    818R For Sale!
    818R Sale Thread
    PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
  10. #1290
    south-central CT
    "Cool" idea! Chad, I think it needs a bullet head on it!
    Perhaps more directed at Wayne, but I plan on having my STi intercooler there and a cover for the passenger side. If my intercooler air dumps into the engine compartment would I need to do something about the potential of flames coming out through it?
  11. #1291
    Clovis, Ca
    I have the aluminum for it. It's on my list. I'm just more concerned about getting the heat problems managed first. That is what the fire system is for, and I will just drive faster if I see flames back there
    Thanks- Chad
  12. #1292
    Clovis, Ca
    Aluminum oil cooler insulated box installed. Insulated with 2000 degree reflective fiberglass tape. Mechie's new rear top louver is on the way to also help with the heat.
    On Monday, I should get Kurk818's Scoops. I will tie in the 3" duct hose with the scoops and a connector duct. (Disregard the duct hose spaghetti back there, I need to trim the hose and make a better path- it's just laying there for now.)
    Thanks- Chad
  13. #1293
    Chad
    Have you considered adding an electric radiator fan to push hot air out of the back of the car?
  14. #1294
    Mechie3's Avatar
    Indianapolis
    Chad, the louver shipped out Weds am via USPS. It will probably arrive tomorrow. It was sent priority. When it comes, use the brace as a guide to get the right bend angle. Once bent, it might need a burr or two removed that couldn't be reached with it in the flat position. Insert the first fin into the brace and then work your way back. Once they were all sitting in place I stood it up on end (wide end on the table with the outside frame touching) and tapped on the flat end of the brace while holding one fin at a time starting from the front. The brace for the first two prototypes (yours and mine) was tighter than my second round test which is why the hammer is needed to tap it in place. Even though it's tight, either weld it or epoxy the brace on with panel bond from the underside.
    Cut out the entire deep depression and most of the shallow depression. The last fin should hang 1/2 over the shallow depression for looks. If you want to cut it open more you could.
    Zero Decibel Motorsports
    Check out my new website!
  15. #1295
    Aug 2013
    You're on speed density, right?
  16. #1296
    Clovis, Ca
    No SD. Tuner said we could, but for what we are doing (detuning) he said it really didn't matter either way.
    Thanks- Chad
  17. #1297
    Clovis, Ca
    Chad
    I'm hoping the scoops will alleviate that. Going fast on a race course, you would think air flow would not be that big of a deal with all the 818R openings.
    Thanks- Chad
  18. #1298
    Clovis, Ca
    Mechie's New rear vent louvers on. It looks really good. It is much bigger too which is great.
    Sorry for the crappy pictures. I'll take some better ones outside this week.
    Thanks- Chad
  19. #1299
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Sigh.
    *Gets out wallet*
  20. #1300
    Puyallup, WA
    You'll love the scoops. I went for a 35 mile drive yesterday with no other cutouts besides the opening for the RMIC, the preintake temps were in the 70s with the hot side in the up to 180* at times.
    Its a blast to drive
  21. #1301
    Quote Originally Posted by Kurk818 View Post
    Great news Kurk,
    Do you have wheel wells and floor sheet metal in?
  22. #1302
    Puyallup, WA
    [QUOTE=Bob_n_Cincy;197086][QUOTE=Kurk818;197084]You'll love the scoops. I went for a 35 mile drive yesterday with no other cutouts besides the opening for the RMIC, the preintake temps were in the 70s with the hot side in the up to 180* at times.
    Great news Kurk,
    Everything is in. Very minor rubbing on the outer lip fiberglass on hard cornering in the front with 255s. Im not complaining
  23. #1303
    Edmonton, Alberta
    Chad, have you considered using a different mesh on the back bumper that will flow more? Have you tried just removing it at the track? That might be a huge contributing factor in the overheating problem.
    Also, both Mechie's louvers and kurts scoops look great!
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  24. #1304
    Clovis, Ca
    This mesh is really open. Its not the restrictive FFR supplied kind.
    Thanks- Chad
  25. #1305
    QC, Canada
    Wow, you seem to have a lot of heat problems. Really nice to see all the solutions put together.
    Say, you fitted the under radiator alu panel WITH the race splitter? I thought the splitter was replacing the louvered under radiator panel.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  26. #1306
    Mechie3's Avatar
    Indianapolis
    The under aluminum is really needed to support the side radiator aluminum pieces.
  27. #1307
    Clovis, Ca
    Just some teaser pictures-
    Kirk818's scoops came today. They are excellent quality and the fit so far is great. I'm not just saying that. The quality and finish is better than my 818R fiberglass. I wanted everyone to know that I paid for these scoops also, so I'm not biased
    There are a few different ways to mount them. I have only worked on one side tonight, and have not finished it completely. The 3" duct hose to my oil cooler box fits in the top part of the scoop perfectly. I plan on painting the inside of the scoops Matt Black. The white gelcoat is a perfect match to the body.
    I also requested him leave the bottom lip of the scoop on, it adds another 5/8" of "Air Grab" to the bottom of the vent. You can see on his 818 the bottom of the scoop is flush, mine has that lip. Enough talk-
    Thanks- Chad
  28. #1308
    Hindsight's Avatar
    Atlanta
    Looking good. Is there enough room in the side sail to recess the area toward the inside of the scoop more inward to help create more of a low pressure area and a larger opening like a naca duct? It would obviously require some fiberglass fab work.
  29. #1309
    Clovis, Ca
    I guess that would be possible. There is alot of room under there. When cutting the side sails even more, I was careful to watch for my IC and coolant lines with my body saw.
    Thanks- Chad
  30. #1310
    Hindsight's Avatar
    Atlanta
    At some point I would really love to see something like this (from a scoop standpoint). You could do it without the deep door recess by simply making the scoop larger and and extending out to the same width as the edge of the fender flares. It would be a bigger piece to make and bolt on, of course:
  31. #1311
    Clovis, Ca
    KAAA CHOW!
    Thanks- Chad
  32. #1312
    Aug 2013
    Santa Rosa CA
    Hey Chad did the rear links cure the tire rub? Any idea where you are with ride height. I do appreciate you R&D. Work has been very busy and I am still a couple of months from road worthy.
  33. #1313
    south-central CT
    I think that Kirk's side scoops will be a big improvement. They look like they should be an improvement. I know that the interior (to the frame) has room for the fiberglass to move inward well over an inch. This might well help in addition to his bigger scoop, but as discussed there are aero issues that need to be addressed so the airflow is not too turbulent when it gets there.
    Everything about Kirk's scoop appeals to me except for the detail at the top. All the other lines flow well; the top does not. Purely cosmetic, but it does not work for me.
  34. #1314
    Hey Scargo I think the issue with the top of the air scoop isthe drivers side fuel filler, to go higher and more contoured to match the rear quarter the filler needs to be shaved, now if a guy had a front fuel tank or fuel cell this could change the shape of the scoop. Let's see how well this design works. Then make some changes if needed.
  35. #1315
    Research Calibrator
    Portland, OR
    That looks awesome! I'm glad I am getting a set of those side scoops!
  36. #1316
    Puyallup, WA
    Quote Originally Posted by sponaugle View Post
    I should have yours ready to ship Friday.
  37. #1317
    Mechie3's Avatar
    Indianapolis
    The very top line of the scoops was made (I'm assuming) to match the slight depression already in the body work from FFR. The FFR side inlets look a bit like a converging nozzle going front to back while the top of the side sail is a a diverging nozzle.
  38. #1318
    Bowling Green, KY
    Good looking race car Chad.
  39. #1319
    Clovis, Ca
    Quote Originally Posted by D Clary View Post
    Nothing worth mentioning yet. I keep changing things. I ordered some new springs front and rear and will be trying those out also. 300/500 is too soft in my opinion, with too much body roll. I may have to try a few sets of springs out, good thing springs are not that expensive. I see double adjustable shocks in my future, if these shocks cant handle stiffer springs.
    I have to look at the rubbing- I have not even checked that yet.
    Thanks- Chad
  40. #1320
    Clovis, Ca
    Thanks- I just wish it ran as good as it looks..... All in due time I guess.
    Thanks- Chad
