Hi all - my first post. The rear-end build video shows the spring coils on the top end of the shock as viewed on the chassis, while the manual I received shows the coils on the bottom on both the front and rear suspensions. Which way is recommended? Also, I'm using the 11.65" disk "Performance" brakes in the rear, and had to make shims for the caliper brackets to be perfectly centered on the rotors. Is this a common problem?
Pix are attached of both front & rear suspensions in my build.IMG_0947b.jpgIMG_0951b.jpgIMG_0969b.jpgIMG_0971b.jpg
Thanks in advance
Jim
