0
FullSizeRender (39).jpgWhat could these be for? Hint: they're big.
I got sidetracked momentarily from the LCA fabricating with the checkout of the STi for a March 28th track day. Now the semi-roller 818 is now out in the cold.
Here's the answer:
FullSizeRender (40).jpg Custom UCA. I took some short lateral link rods (like I have in the rear) and cut them up to make these. Stock Factory Five arms are less than half as long. These are six and seven inches long. Bigger is better! Howe racing ball joint.
Found the STi's rear suspension toe was not what I thought it was. Also with the new HVT recessed camber plates I am struggling to get past -3° of front camber. Don't want to grind on my fancy Motion Control Suspension strut brackets. Well, heck, why not?
Now, with the 5-6 inches of snow we just received I am keeping my fingers crossed that LRP can get the track ready in time. I do have winter tires that will fit...
Reason: Added UCA pic and description
