Page 30 of 54 FirstFirst ... 20282930313240 ... LastLast
Results 1,161 to 1,200 of 2134
Thread: Plavan's 818R Build Thread
  1. #1161
    Mechie3's Avatar
    www.onshape.com
    Request an invite. From the original makers of solidworks. Free CAD for personal use that uses the same parasolid engine as solidworks (and lots of other CAD programs).
    Zero Decibel Motorsports
  2. #1162
    Santa Rosa CA
    What ride height did you start with? I kind of set mine up at 3.5" sounds like you could be getting close to 4.5".
  3. #1163
    Mar 2014
    Oakley, CA
    No need for a sway bar. I was thinking going up 10% on all springs. I'm probably going to have to raise the rear another 1/4" or more.
    Do you think, geometry-wise, we might end up being better off using the S ride height just for clearance?
  4. #1164
    Clovis, Ca
    I'm going to remeasure everything/Corner balance before the next race. I think the front was at 3.75 with a quick raise at the track.
    Quote Originally Posted by Zach34 View Post
    I was wondering that also- But I'm not near the 4.5" mark.... Yet. I did notice the springs did settle quite a bit. The car was handling great last time out, just the drive train was giving me problems.
    Thanks- Chad
  5. #1165
    The lift to drag ratio of the diffuser is a lot better at lower ride heights.
  6. #1166
    Clovis, Ca
    I agree, but rubbing tires is not good at 130-140 MPH.
    Thanks- Chad
  7. #1167
    Tazio Nuvolari wannabe
    south-central CT
    That's great data. I had read that 10-12 degrees was ideal. Who the heck can run even 40mm height to maximize force when we might be at 82mm?
    BTW, when I had a tiny rub, that I could not perceive, my club black-flagged me in a hurry.
  8. #1168
    Feb 2013
    Copperas Cove, Texas
    What angle is the Factory Five defuser at when installed with a level ride height?
    -Jason
  9. #1169
    Clovis, Ca
    Quote Originally Posted by EODTech87 View Post
    I never measured- but it seems to be around 10 degrees.
    I'm almost done with the complete oil cooler upgrade/ducting. I found some other ducts that I think I can modify for the side vents- If not I will go back to the 3D printed ones. I'm just waiting for those to get here then it will be done.
    Anyone know if there is a aluminum piece that bridges the aluminum/front splitter area under the car to under the steering rack? Part number? or am I going to have to make something? It was on my todo list, but I got side tracked and forgot about it until I had to clean all the rubber and track junk out of the front. I want to block it off.
    I started playing and printing these NACA ducts. My printer has been on the fritz lately. I need to do some maintenance on it also.
    Also wanted to point this out. I have the adjustable rear toe links that were sent with some of the early 818S cars (Rubber Bushing). I planned to upgrade to metal Swag tubes, after seeing this, I bought all the parts to convert the 818R over. The rear rubber has a little too much "give". The tire/wheel was defecting enough to rub. This is with both spacers on the "inside" also to give more clearance (to upper bar). Once I get those rubber bushings out, I'm confident this will not happen anymore. It just means it will be even faster.
    Look on the STI pink-
    The culprit:
    Thanks- Chad
  10. #1170
    Mechie3's Avatar
    There's a thread in the body area iirc where someone has a piece to bridge that gap.
  11. #1171
    south-central CT
    Are you planning anything for closing the gap between the diffuser and the rear of the chassis pan?
  12. #1172
    818 Junkie...
    Atlanta, GA
    I have adjustable heim joint connections on all of those points, and the offset lower trailing arm to barely fit the tire on. It does not move a bit.
    818R For Sale!
    818R Sale Thread
    PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
  13. #1173
    Clovis, Ca
    I have already. I took it off to change the oil since I was removing the old oil cooler.
    Thanks Mechie, I'll look over there. I also have an email over to Jim to see if I have a missing aluminum peice.
    Thanks- Chad
  14. #1174
    818 Junkie...
    Atlanta, GA
    You might want to just call Jay, pretty sure Jim is at VIR..
    818R For Sale!
    818R Sale Thread
  15. #1175
    nkw8181's Avatar
    Dallas, TX
    There is a piece of aluminum sheet that comes with the diffuser. If you didn't get it (like me) call ffr and they will send it out.
    Nolan
  16. #1176
    Clovis, Ca
    Here is the rear panel installed I had to call for also.
    http://thefactoryfiveforum.com/showt...l=1#post179423
    Thanks- Chad
  17. #1177
    818 Junkie...
    Atlanta, GA
    No scales yet. Maybe this weekend.
    I was 1775lb at Dixie.
    818R For Sale!
    818R Sale Thread
  18. #1178
    Clovis, Ca
    Quote Originally Posted by bstuke View Post
    That is really nice. Like I said before, the dry sump, wing mount with integrated bumper, a real intrusion panel, fuel cell, AWIC, complete fire system with an additional hand held fire extinguisher all add weight. Added safety is worth the weight. I need that weight for the ST2 race class. If I was just doing autocross, all that stuff would not be in.
    I actually do not mind adding weight since I can just add more HP since it is detuned so much. At the last race, they weighed me coming off the track after the race. I was 4 pounds over my minimum DQ weight .
    I'm just happy I have a motor that is still running strong so far unlike the other 818R's road racing. Going 125- 130mph in sustained high G corners lets me know the dry sump is working. I just need to get the oil temp down a bit (Which could of caused some of the other 818 track cars problems also) which I think I have found the answer to.
    Thanks- Chad
  19. #1179
    Chicago, IL
    SWEET!
    Just make sure to eat lunch before the race. =)
    Executive Director
    The Community Garage
  20. #1180
    Bowling Green, KY
    1775 Very nice, my goal of 2000lb with driver water, oil and fuel is obtainable.
  21. #1181
    Clovis, Ca
    I'm now 2235 w/driver and 4 gallons of gas...... I weigh 180 as a data point. Good luck!
    Thanks- Chad
  22. #1182
    Clovis, Ca
    Air intake upgraded. If I'm not getting cool air now, I have other issues.
    Thanks- Chad
  23. #1183
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Looks perfect!
  24. #1184
    south-central CT
    I think once you're rolling you will be fine. It will be a blast! Some do partition off the filter/intake a little more from the engine compartment.
    On the weight issue: I weight 165 and my pistons are 22 grams (each) lighter that stock. My rods are light. My front uprights are lighter and my LCAs will be 3 pounds, each lighter. I've lost the door hinge mounts and lots of other extraneous metal and fiberglass. I'm going to try using an STi intercooler stuck out into the airstream. May be ugly... Dry sump might add weight. I'm planning on being under 2000 with me and 5 gallons.
  25. #1185
    Orange, CA, USA
    Do you know how much static clearance you had at that location? I'm wondering how much the tire deflected.
  26. #1186
    south-central CT
    Oh, the terminology! I think lateral arms (then lateral links) are more standard terms than toe links. If toe, then you could call them camber links, too.
    Please understand that I have worked with a (professional) fellow who is a stickler for suspension terminology. I (and he) cannot even get it straight half the time.
  27. #1187
    Clovis, Ca
    Really? The rear most lateral link is used to adjust toe. Call it what you want. No need to have a discussion about it. Other than Subaru's they are also known as toe links, why? Because they adjust the toe.
    Thanks- Chad
  28. #1188
    south-central CT
    OK, fine. No discussion. Don't get your nickers in a twist.
  29. #1189
    Clovis, Ca
    Just an FYI- Drilling the inner tab mounts for upgrading to 12" swag tubes in the rear is a BIG B. You have to enlarge the holes to 5/8" on the front mount tabs. PITA trying to get a drill in there. I think I'm going to have to die grind the rear hole on both sides (near motor mount) I have tried and angle drill, angle drill attachment with a step drill, filing, grinding- it sucks. nothing can get a straight shot. I'm waiting on some new die grinder bits to have another go at it.
    However, drilling the rear hubs to 5/8" was easy.
    Thanks- Chad
  30. #1190
    Hindsight's Avatar
    Atlanta
    Why do the holes need to be enlarged for longer swag tubes?
  31. #1191
    Clovis, Ca
    The rear tabs are 5/8" holes up top "R height", the front tabs are M10 or M12- I can't remember but much smaller than 5/8". I'm not sure if the later chassis are like mine.
    You basically need to change everything to 5/8" (hub also) so you can use the standard swag tubes and rod ends. They are a lot cheaper than metric. You can keep limited spares that fit a bunch of places instead of carrying metric and imperial.
    It explains what you need in the 818R supplemental, just not how hard it is to drill some holes
    Thanks- Chad
  32. #1192
    Wayne Presley's Avatar
    Enterprise Alabama
    Later R chassis have 5/8" holes on the upper hole and 12mm on the lower hole.
  33. #1193
    Clovis, Ca
    Well that does not help me
    Thanks- Chad
  34. #1194
    Chad
    It the original hole was 1/2", could you just add a 1/2 to 5/8 sleeve.
    If 12mm these 12mm-16mm sleeve would be very close. http://www.mcmaster.com/#6658k16/=whh9bl
    The are about 0.004" to big. Might have to sand them down a smidge.
  35. #1195
    Enterprise Alabama
    Or put a rod end that threaded 5/8-16 and has a 1/2 hole in the rod end
  36. #1196
    Clovis, Ca
    That would of been too easy. I like doing things the hard way. I'll just die grind out the front hole.
    I was dumb and just tried the rear most tabs first- of course they were 5/8" already. I figured the front ones would be too. My fault.
    Thanks- Chad
  37. #1197
    south-central CT
    I lucked out and got the 5/8" holes... Could you create a stubby 5/8" bit and perhaps grind the flats that would get it into a six-point socket? Or weld it to a socket. I have a 3/8" air ratchet that can get into tight spaces.
  38. #1198
    Bowling Green, KY
    I shortened a 5/8 bit to get the job done, not a problem.
  39. #1199
    Clovis, Ca
    I have tried that, but my angle drills will not fit. What drill are you using?
    Great ideas everyone. I'm hoping to get everything done today without it looking like a Hack did it......fingers crossed
    Thanks- Chad
  40. #1200
    WI
    Maybe a pneumatic drill would fit?
