Results 1 to 9 of 9
Thread: Is the coil over or under on the coil-overs?
Threaded View
  1. #2
    At the build school, they had the front springs on the bottom and rear springs on the top (they mentioned that it does not matter which way the coils spring is located - up or down).
    On my build I have both front and back coils toward the bottom as you have installed (if found better clearance in that position)
    15th Anniversary Edition
    Mk4 - 18 month build (4 hrs every Sat), received Aug 2011, titled & registered May 2013, final in paint Nov 2013 - Ferrari blue
    FRPP Crate Coyote 5.0, tko600, Moser 3 link, manual steering & 13" brakes, upgraded coil overs
    koolmat then dynamat then carpet in cockpit - very solid, no engine heat transfer to cockpit and no road noise
