Results 1 to 5 of 5
Thread: IRS Circlip source needed
    Swapping out hot wheels:)
    Raleigh, NC
    Question IRS Circlip source needed
    I'm assembling an IRS on a MKII Roadster and am in need of two circlips used to hold the axle shaft onto the tri-lobe bearing and the outer CV. The Ford '97 Thunderbird part numbers are E9SZ-4K184-B and E9SZ-4K237-B. Auto parts say its a Ford supplied part and Ford says they are discontinued. I've done web searching with no luck. Does anyone know where I can get these? I need two of each. See pic.
    2025 May: MK5 Complete kit, Blueprint 347 EFI, 4R70W (current build)
    2019 Nov: '35 Hot-rod Truck, 306, EFI, 3-link (screwed by NC DMV)
    2015 Mar: MK4 Complete kit #8617, 302 create, carb, 3-link
    2014 Sep: MKII Kit #4215, 302 create, carb, IRS, Sold as roller
    2011 Mar: MK3 Base Kit #5400, 4.6L Fuel Injection, Daily driver
    Stafford Virginia
    Try mcmaster.com they have a wide variety of items
    JR
    Colorado Springs
    They are hard to come by. I got mine from Mike Forte. You can also (usually) get them from Disc Brakes R Us.
    .boB "Iron Man"
    NASA Rocky Mountain, TTU #42, HPDE Instructor - Retired 10/24
    www.RacingTheExocet.com
    Jun 2014
    Rock auto has 4473282 part number for the clip. Said 3 available.
    Raleigh, NC
    Thanks all! Mike Forte was able to get his hands on the outer clips for me. I'm still trying to source the inner (thick) clips.
