Has anyone got a solution for installing the air intake in the 33HR using an LS3 engine?
The intake is 4" diameter and the install manual says the mass flow meter needs to be 10" away from the throttle body. With that 10" plus the cone filter. I'm not seeing a way to fit this in? Suggestions anyone?
