image.jpgI've searched the forum, but I could not find any pictures or solutions to my problem. My door frames have been mounted as described in the build manual, but the front edge of the door frame ends up tightly wedged between the window frame at the top and the sill at the bottom, even with the windshield mounted at the highest possible position.
I've checked that I am using the proper hinges in the correct positions, but it all seems far too tight! There isn't nearly enough room for the door skin above and below the frame, or for the mirror bracket on top as well.
Has anyone else run into this, and how did you solve it?image.jpgimage.jpgimage.jpg
