Results 1 to 5 of 5
Thread: Mounting door frames
    Calgary
    image.jpgI've searched the forum, but I could not find any pictures or solutions to my problem. My door frames have been mounted as described in the build manual, but the front edge of the door frame ends up tightly wedged between the window frame at the top and the sill at the bottom, even with the windshield mounted at the highest possible position.
    I've checked that I am using the proper hinges in the correct positions, but it all seems far too tight! There isn't nearly enough room for the door skin above and below the frame, or for the mirror bracket on top as well.
    Has anyone else run into this, and how did you solve it?image.jpgimage.jpgimage.jpg
    TriguyDave
    818 noobie builder
    First start: Sept 28, 2014
    Go-carted: Oct 4, 2014
    Registered and Street legal Sept 30, 2015
    Calgary, Alberta
    Calgary
    Missed the last picture. Attachment 38385
    TriguyDave
    818 noobie builder
    Calgary, Alberta
    Make sure you have the windshield tilted back far enough. It has to tilt back not forward to get clearance.
    Calgary
    Thanks for the tip. I'll try that out.
    TriguyDave
    818 noobie builder
    Calgary, Alberta
    May 2013
    Greenbelt, MD
    Were you able to figure it out? I looked at my car and I have about an inch of clearance, but it doesn't seem like I did anything differently from you. I did try to match the measurements given in the manual update for people planning on eventually buying a soft top. It would be interesting to see if you are close to those specs.
