Results 1 to 5 of 5
Thread: Steering Wheel Options
    Clearwater, FL
    Question Steering Wheel Options
    I've seen the various wood and leather steering wheels offered by FFR and **********, but I was interested in finding a 14" Alcantara (faux suede) steering wheel, either round or D-shaped, that is a direct fit. I like the 3-spoke look of the one's offered by FFR and **********, and prefer that in polished, but I am open to anodized black spokes as well. I realize our cars have the English 6-hole configuration where the holes are offset and not equally spread. So my questions are:
    1. What options are out there that are direct-fit?
    2. If I go with a quick-release hub will that open the door to more options?
    3. Is there a way to change the English-6-hole to something more standard to open up more options?
    Pictures and links always appreciated. Thanks!
    Mark IV Roadster #7679
    Coyote 5.0, T56, Hydraulic Clutch, IRS, Torsen Diff, Wilwoods, Hydraboost, ABS Power Brakes, Power Steering, & tons more extras.
    Sep 2014
    Why not have an upholstery shop cover the wood wheel with the material, or better yet with leather?
    Mk 4 roadster #8495 delivered on 12-23-2014. Build thread: http://thefactoryfiveforum.com/showt...r-Build-Thread Carbureted 4.6 SOHC, C-4 auto with manual valve body. Fox width rear with 2.73 gear. First start video:https://www.youtube.com/watch?v=v8ie...ature=youtu.be
    Clearwater, FL
    Ideally I'd like to go with a hub, keep the wood one and swap it out with a super-comfy one for daily driving. I could cover it, but I am looking for other options.
    Here is a quick release hub.
    http://www.breezeautomotive.com/deta...413&cat_id=12#
    I would call Mark and ask about other bolt patterns. He also sells and extra hub for exactly what your are thinking.
    http://www.breezeautomotive.com/deta...=432&cat_id=12
    If he can supply other patterns or an undrilled hub, that would open up a ton of wheel options.
    Clearwater, FL
    That is a good idea. Thanks.
