Page 25 of 54 FirstFirst ... 15232425262735 ... LastLast
Results 961 to 1,000 of 2134
Thread: Plavan's 818R Build Thread
  1. #961
    Clovis, Ca
    I'm using the supplied proportioning valve that I modified for real time adjustment on the dash.
    I went with the Raybestos racing pad ST45. I usually use ST43 but they they said I should try the 45 for the same characteristics, just a little more friction.
    Thanks- Chad
  2. #962
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    .... And what were you using before (so i can steer clear)
  3. #963
    Clovis, Ca
    What ever came with the Wilwoods. I think BP30 pads- horrible.
    Thanks- Chad
  4. #964
    Hindsight's Avatar
    Atlanta
    Good to know. Glad you found something that works. Will go a long way to making that next test session more enjoyable.
  5. #965
    Santa Rosa CA
    Where did you get them Chad the only thing I have fount through wildwood is a bp30. Is there a raybestos part #for the application? I think we have the same brakes.
  6. #966
    Clovis, Ca
    http://www.porterfield-brakes.com/ They will set you up. They carry all the popular race pads. Just let them know what caliper models you have. I don't have part numbers handy.
    Thanks- Chad
  7. #967
    Clovis, Ca
    I was able to mess around with the car today. I cut an additional vent in the rear and covered it in mesh I picked up. I didn't like the FFR "mesh" as it does not allow alot of airflow.
    The light reflection on the trim plays weird with the camera- makes it look wavy. In person it looks good and straight.
    I also finished up the hatch cut out.
    Close up of aluminum grill mesh.
    I'll finish the bottom rear vent after I install the new turbo and injectors. I already started removing the old TD04 turbo.
    Thanks- Chad
  8. #968
    Wayne Presley's Avatar
    Enterprise Alabama
    Chad, what turbo did you get?
  9. #969
    Clovis, Ca
    Well, I asked "Santa" for a Blouch Dom 1.5xtr 10cm and Injector Dynamics 1000cc injectors..... I have been a very good boy. haha
    Thanks- Chad
  10. #970
    Mechie3's Avatar
    Where did you get the mesh? Is it flat perforated metal or ribbed expanded metal? That's the same pattern and size hole I've been looking for.
    Zero Decibel Motorsports
  11. #971
    Clovis, Ca
    Ribbed expanded aluminum. Its really light/bendable so you can use it on curved stuff if needed.
    I bough a 12x48 piece off of Ebay. ~$28 shipped. (search for grill mesh)
    Thanks- Chad
  12. #972
    nkw8181's Avatar
    Dallas, TX
    Is that the honeycomb or diamond?
    Nolan
  13. #973
    Clovis, Ca
    Quote Originally Posted by nkw8181 View Post
    Its more Honeycomb than Diamond.
    Thanks- Chad
  14. #974
    Clovis, Ca
    Well something showed up early!
    I also went and picked up a sheet of aluminum (.060) to make my fuel cell firewall. I grabbed a ton of poster board to make the template.
    Thanks- Chad
  15. #975
    Clovis, Ca
    Post Xmas update.
    I removed the TD04 without much hassle. But when trying to install the DOM 1.5, since it is bigger, it will require a little more work to get in. When trying to install it, it hits the shock tower brace. I may try and remove the up pipe, or the studs first. If that does not work, I will have to remove the shock tower brace/ wing mount.
    Moral of the story, if you plan on upgrading the turbo, do it sooner than later.
    Thanks- Chad
  16. #976
    Hindsight's Avatar
    Atlanta
    Wow, I'm surprised a stock-location turbo won't clear the brace. That brace is REALLY in the way. Would be nice if FFR re-designed it at some point to give better clearance Clarence.
  17. #977
    818 builder
    Exeter R.I
    Funny cause my dom 1.5 ts fit better than the stock vf37 ts
  18. #978
    Clovis, Ca
    Did you remove up pipe first? Or just throw it on?
    Thanks- Chad
  19. #979
    NoVA
    Let me know if you decide to part with the shock tower brace and wing mount. I liked the way you had it laid out and would be easier to not rebuild it.
  20. #980
    Clovis, Ca
    Quote Originally Posted by metros View Post
    It just hits when installing, I just loosened everything up (Rear shock mount, removed shock bolts, removed rear wing mount bolts, drilled out rivets for body on shock brace, etc) and I can get turbo on. It's just a PITA to have to do all that to get a new turbo on. It doesn't interfere once its on the up pipe studs.
    Now I'm running into a different problem I need some help on.
    http://thefactoryfiveforum.com/showt...tall-questions
    Thanks- Chad
  21. #981
    Clovis, Ca
    Alright- I got the turbo installed with some help from this forum (Thanks!). I'm just clueless with turbos and this is my 1st time messing with them.
    Next is replacing the injectors. It shouldn't be too hard, but I'm sure I will run into some issue. Murphey's Law and all.
    Thanks- Chad
  22. #982
    Tazio Nuvolari wannabe
    south-central CT
    You will love the turbo. We are here to help/hinder or both. Bring on the injectors! Do you have a good fuel pump (up to the task)?
  23. #983
    Clovis, Ca
    Yes- I had Fuel Safe throw a upgraded Walbro in the fuel cell.
    Thanks- Chad
  24. #984
    Apr 2014
    Shelton, CT
    Are you using the Plug and Play adapters for the ID1000's?
    Tamra
    First autocross 3/29/15
  25. #985
    Clovis, Ca
    Yep. Santa brought those also.
    Thanks- Chad
  26. #986
    Clovis, Ca
    This should be interesting.
    Thick Gold Chains not included.......
    Thanks- Chad
  27. #987
    nkw8181's Avatar
    Dallas, TX
    I look forward to hearing the results!
    Nolan
  28. #988
    818 builder
    Exeter R.I
    Good luck, stay safe!
  29. #989
    Clovis, Ca
    Thanks- Still have 2 months until the first race. I want to test a couple more times before then.
    Thanks- Chad
  30. #990
    Hindsight's Avatar
    Atlanta
    Oh man, that looks like a great race!
  31. #991
    Clovis, Ca
    My racing buddy and I started installing the Fire System today. We got the Fire pulls all figured out and routed, and started the hardline route. We are going to have 2 nozzles on the driver, one on the fuel cell, and 3 on the motor (Turbo/pass injectors, middle, driver side injectors/fuel lines). Should be pretty straight forward. I need to make some mounts for a couple of the nozzles.
    I also got the rear end wing mount/shock strut/ shocks back on. I started up the car with the new turbo to check for leaks. All good! I will probably get to the new injector install tomorrow.
    Happy New Year!
    Thanks- Chad
  32. #992
    south-central CT
    I got this OMP system from Pegasus. Five nozzles and 2.8 L of "Ecolife film forming foam". I don't have a clue how to route it. I see OMP is now offering it with seven nozzles.
    I am surprised that there would be nozzles directed at the driver. It would be nice if I could get some guidance on nozzle placement and, since this system is so important, routing of the tubing, placement of the tank and so on. I do know a couple of people that may know. Suggestions?
    Car's looking good!
  33. #993
    Clovis, Ca
    Car's looking good!
    I'll take some pictures when I'm done. But you want at least one nozzle on the driver area spraying mid torso down. You don't want to be on fire either
    Thanks- Chad
  34. #994
    Enterprise Alabama
    I'd do one spraying on the upper rear corner of each head, one on each front each head spraying the front of the motor and back of the fuel cell and one on the side of the driver spraying from the knees to the shoulders
  35. #995
    Clovis, Ca
    I was able to get all the new injectors in. Not too bad to install except the passenger front injector. That one was a PITA- Luckily I removed the "Green Brackets of Death" before I installed the motor.
    I also picked this bad boy up for 45% off.... I always wanted one of these to fab aluminum pieces. I added some casters with brakes so I can store it easily. This will help big time for the fuel cell firewall box I'm making.
    I am going to try and call the Tuner on Monday to make an appointment. It will probably be an all day thing since he is 3 hours away. I will need 2 race tunes, one for ST2 (around 270HP) class and one for ST1 (around 360HP) class. They are both HP/weight classes. That way, I can just pick who I want to race with if one class has a bigger field for tire contingencies.
    Thanks- Chad
  36. #996
    Hindsight's Avatar
    Atlanta
    Nice idea on a tune for each class! Should be able to hit 360 on that dom 1.5 on 91 octane but I would bet it might be close (unless you are using race fuel in which case I think 360 would be very easy). Are you going MAF or speed density?
  37. #997
    Clovis, Ca
    Whatever the Tuner recommends. I'm clueless with this turbo stuff . Its all a whole new world for me. I will be using a minimum 100 octane.
    Thanks- Chad
  38. #998
    Hindsight's Avatar
    Atlanta
    Oh, no problem making 360 at the wheels on 100 octane race gas for sure.
    MAF = Uses hot wire sensor in intake to measure mass of air in order to determine fuel needed. Also uses a vac/pressure sensor.
    Speed Density (also called MAP) - Uses only intake temp sensor and vac/pressure sensor to determine fuel needed.
    Both of course use crank position sensor, etc.
    I think MAP would be better for your racing application but that's just me. Will be interested in what the tuner says.
  39. #999
    Curious, what's the max available? 110?
  40. #1000
    south-central CT
    I never thought of keeping my options open as far as class goes. Cool.
    My tuner did SD. I think that's probably where you are heading.
    I forget your engine specs but 400 should be easy with 100 octane. Perhaps even 93. I'm doing 400 at all four wheels in my STi with stock cams, but it's a DAVCS motor. Blouch 2.5 Dominator XTR with small turbine side.
