Thanks Brandon. We ran CW #13 the same as you. Since I had never run with them before, and was testing a new car they threw me in Advanced Intermediate. It had the dumb point by rules too. They said I could go to the higher group after the 2:01 but I would of lost a full session. I was running the same times as the advanced group (one guy was running 1:57's though). It was a little frustrating, but I was just there to test the car.
Other good data:
Oil temp: Even with my 8 qts of oil and cooler, the oil was getting to 240 degrees. I am going to vent the rear bumper more. The damn thing traps heat. I cant imagine the temps without a cooler. Element Tuning says they can see above 250 in their race car.
Coolant temp: never got above 220. Mostly in the 210 range.
AWIC temp: Never got over 120 degree's that I recall. I will look at logs. (around 75 degrees mid day)
Brakes: I'm not a fan of the stock pedal and Wilwoods. You have to stand on the brakes with alot of force. I plan on upgrading the pads to a racing set I know well to see if that helps with bite.
After a good run, tighten down all your hose clamps on you coolant lines/tubes. I caught one weeping on the engine (thanks to under engine tray)
Ditch the center rear view mirror- it was in my line of sight to where I could not see apexs etc. I took it off and was much more comfortable. The side mirrors (convex) provide more than enough vision.
PS I asked Santa this AM for a bigger turbo and injectors for Xmas.I need to see where I would fall in ST1. The TD04 is not good for racing because it poops out too soon. Not to mention I have 272 cams, so its really miss matched.
That's one way to fix it!
