Page 14 of 20 FirstFirst ... 41213141516 ... LastLast
Results 521 to 560 of 779
Thread: 818Rasmus E Modified
  1. #521
    18.0.E.3. Driveshaft Hoop: RWD DM and EM vehicles shall have a drive-
    shaft hoop capable of preventing the shaft from entering the driver’s compartment or damaging any
    fluid or electrical lines in the event of joint or shaft breakage. All cars in competition us- ing
    open driveshafts must have a retainer loop with 360° of en- closure, ¼ inch (0.250”; 6.35 mm)
    minimum thickness and 2.0” (50.8 mm) wide, or ⅞ inch (0.875”) x 0.065” (22.23 mm x 1.65 mm) welded
    steel tubing, securely mounted and located so as to support and contain the driveshaft in event of
    U-joint failure. Vehicles that have a closed “tunnel” or other such structure which the driveshaft
    passes through such as the vehicle’s frame, may be considered for an exemption from the SEB if that
    structure meets the criteria stated above.
    Note: DM and EM vehicles are exempt from the scattershield,
    driveshaft hoop, and Master Switch requirements if they are using
    DOT-approved tires.
    Bold for emphasis.
    Could well be that the bellhousing counts as a scattershield. Either way, DOTs reads to me as not needing the switch.
  2. #522
    Las Vegas, USA
    Agreed. I'd interpret it that way also. Thanks for the clarification.
  3. #523
    Tazio Nuvolari wannabe
    south-central CT
    Certainly not in drag racing. Aluminum bellhousings have never been considered a scattershield.
    About Matchbot: I think it can be a great too if used wisely and realistically. I sure hope my BW EFR 8374 doesn't put out a Brazillion horsepower at 32 PSI. If it does, my pricey built motor will last about two seconds.
  4. #524
    Apr 2014
    I was just about to say the same thing. If you need a scattershield in NHRA, you need to either swap bellhousings to a SFI approved one, or add on one of the SFI approved strap-style ones that go over and around the trans.
    That said, the rules were obviously intended for a front-engined car with the clutch near the drivers ankles... so there may be a work around with that.
    edit: note that if an aluminum bellhousing counted as a scattershield, almost no car would ever need one.
  5. #525
    Auto-x is a little different. This is SCCA Solo's definition of scattershield
    The following shall be required in all Modified Category vehicles:
    1. Scattershields/Chain Guard:The installation of scattershields or
    explosion-proof bell housings shall be required on all cars where
    the failure of the clutch, flywheel, or torque converter could create
    a hazard to the driver or passengers. Chain drive cars shall be
    fitted with a protective case/shield to retain the chain in case of
    failure.
    The following material requirements apply to scattershields/explosion-
    proof bell housings:
    ⅛ inch (0.125”; 3.18mm) SAE 4130 alloy steel
    ¼ inch (0.250”; 6.35mm) mild steel plate
    ¼ inch (0.250”; 6.35mm) aluminum alloy
    SFI or NHRA approved flexible shields
  6. #526
    Las Vegas, USA
    Started on the wiring harness. Just stripping off the outer sheathing. Intimidating looking at all those wires. I suppose once I remove the ABS, Airbag/SRS, Window, and Lock wires it'll be easier to get my head around.
    Unfortunately, most of the day I dedicated to the German car. I swear, if FFR based their kits around German cars they'd go out of business in 18 months. So. Hard. To. Work on.
  7. #527
    fasterer and furiouser
    I once volunteered to help my fried do an oil change and front brakes on his Passat. never again.
    plastic dipstick and tube crumbled in my hand, brake pad sensor self destructed. I went to 3 VW dealers, the third finally had the parts/ was open on saturday,
    "oh that happens all the time, make sure no big pieces of it got down into the motor, you should probably drop the pan"
    me: what? "yeah we don't touch them, we just add the right amount of oil"
    in conclusion
    sorry for your pain
  8. #528
    south-central CT
    I love our Bimmer. A 2010 535XI with M package. Turbocharged... It scares the hell out of me when I open the hood. A sea of plastic! I changed a running light in the front and it was all I could do to get my hand in there. I thought I would have to start disassembling the front end to change the bulb.
    I now know my '08 STi pretty much inside and out. I don't want to know about the Bimmer...
  9. #529
    Freeport, ME
    I love working on my Bimmer, so easy... it is a 91 E30 convertible tho!
    Dan
  10. #530
    Las Vegas, USA
    Removed most all of the sheathing on the chassis' main harness. Didn't get to the engine (in black bin) or intake manifold harnesses (not pictured). I stuffed what I think is the airbag/SRS chassis side harness in the small box on the left there.
  11. #531
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Nice. I JUST finished pulling all my wiring out and am sitting down for lunch before I head back out and get the last remaining thing from the donor: the fuel tank. Then it's chop chop and off to the scrapper.
    I'll be watching your wiring progress closely. Do you have any de-pin type tools? If so, where is a good place to get them?
  12. #532
    Freeport, ME
    don't bother, no one has found a good working pin tool, cut and splice as needed
    Dan
  13. #533
    818 builder
    Exeter R.I
    Re pining looks nice though
  14. #534
    Vancouver, BC
    Are the pin removal tools referenced in this PDF useful for these wiring harnesses?
  15. #535
    We were doing the same thing today. Separated the ABS/SRS from the harness & engine harness, then deleted all door stuff, shorting the door switches, and deleted all the radio/clock/ac bits, too.
  16. #536
    Oct 2014
    You can run whatever tires you want in Prepared and Mod, provided they don't explode or are unsafe. You could make your own if you want to.
  17. #537
    Las Vegas, USA
    Arrived home today and the garage door wouldn't open. Unfortunately the S.O. arrived before I did. She said, "I tried it like 10 times outside and it wouldn't go up, so I went inside and tried it a dozen more. Nothings blocking it so I don't know what's wrong." Looks like the poor garage door opener just about ripped it's mount out of the door frame trying to lift the door on a broken spring. So there were go.
    I get to replace both torsion springs and also repair the mounting location for the garage door opening arm.
  18. #538
    Ugh. If you replace the spring yourself, be careful!!
  19. #539
    Encinitas, CA
    Hindsight's Avatar
    Atlanta
    Ugh! The spring looks so new too. I recently had to replace my entire door and spring as well. One of the few jobs I chose to call in a pro for. They are cheap. Good luck.
  21. #541
    south-central CT
    Shorten the other side an equal amount and make it into a "high-performance" door opener. Sorry...
  22. #542
    Mechie3's Avatar
    I used a small precision screwdriver to depin. Works for everything except the ecu connectors.
    Zero Decibel Motorsports
  23. #543
    The energy tied up in a wound garage door spring is quite substantial. I always get the type in the enclosed tube that you preload with a drill after it's installed.
  24. #544
    When I was a kid. I was working on a car in the garage (under the living room) when one of the cable, spring, pulley types let loose.
    It was so loud that my parent (in living room) thought the car fell on me.
  25. #545
    RE: Garage door springs.
    Lots of good info, video's, and parts: http://ddmgaragedoors.com/diy-instru...on-springs.php
  26. #546
    Freeport, ME
    One of mine let go a couple months ago... new steel insulated doors are on order, current doors almost 29 years old
    That noise when it pops was very frightening!
    Dan
  27. #547
    Las Vegas, USA
    Ordered two new springs for the garage door from Amazon. One left wound, one right wound. Was about to order a set of winding bars, but at ~$20 for one, need two, I figured I could make my own and save $40. So custom welded up two garage spring winding bars. 18" long with 1/2" rebar. I've tried unwinding garage springs before with just 1/2" rebar and it gets super sketchy with the rebar bending. So I beefed 'em up with some rusty old angle iron my kid found in the desert. So, garage springs all unwound. Body safe. I'm sure glad I haven't had shoulder surgery in the past year because that might have really tested the rehab.
    And this surprised me. 4.533 kg for full steering column. I'm gonna need to find a way to reduce this considerably, because that is a bunch of mass.
  28. #548
    Harley818's Avatar
    Vancouver BC
    you could use all that weight you have been saving as a counterweight....... just saying....
  29. #549
    Apr 2014
    You know I see you on here almost everyday... but its been 5 days and no update? Unacceptable.
    lol, seriously though, i just popped in because I had an idea about your column weight. How much of that weight is for the column key lock? not the switch itself, but the lock to keep the wheel from turning, and brackets to brace that lock? between that and replacing the tilt mechanism with a simple bracket, you can probably cut most of that mass off. You shouldn't need tilt once its at your preferred height, plus the wheel comes off to get in and out, right?
  30. #550
    Las Vegas, USA
    Quote Originally Posted by MrDude_1 View Post
    I'm totally slackin' here.
    Nah. Just bad planning.
    I've got currently five projects up in the air.
    • Garage door repair (springs arrive today)
    • Transmission speedo gear & lsd install (speedo gear on order at local Subaru Dealer)
    • Short block build ( rotating assembly at machine shop )
    • Steering column install (parts arriving today)
    • Subie Invasion 2014 Group Drive Rally-master (on going)
    I find if I get too many things going I get over whelmed and don't want to do anything. 5 is pushing it for me. But it's, honestly, just bad planning. I tend to go in waves of 1. plan 2. order parts/service 3. fabricate-install. Problem is when I get to fabricate-install I tend to do everything on my plate until I've got nothing to do and haven't planned anything or ordered anything. I came to complete halt with everything in the order phase.
  31. #551
    Hindsight's Avatar
    Atlanta
    Better to have that than the far more common problem of ordering a bunch of stuff that you then never install.
  32. #552
    best link posted to date.
  33. #553
    Feb 2014
    Asheville, NC
    Any significant weight savings from the new garage door springs over the old ones?
  34. #554
    Las Vegas, USA
    The steering column. From 4,533 kg to 1,955 kg. Some of that I'll need to add back in for the indicators, ignition, start, and accessory switches. Also the key and it's RFID reader. So for final install I probably shaved 2.5 - 2.4 kg. Which is heeps.
    That's a M22x1.5 rod end holding up the steering column now. Notice how I hollowed out the threaded portion to save weight. I think I might have a condition.
  35. #555
    Las Vegas, USA
    Cut down and reused the factory lower bearing to pass the column through the fire wall
    I'll need to replace that zip tie with a metal hose screw clamp. Wouldn't want that to slip out.
    Garage door update! I ordered the wrong springs!
  36. #556
    Australia
    I can see at least 10 threads not being used on that rod end. I'm surprised you haven't cut them off to save a bit more weight.
  37. #557
    Chicago, IL
    Very cool OEM column mods! If I wasn't thinking that others may need to quickly adjust controls (think "enduro") I'd probably go this route.
    Executive Director
    The Community Garage
  38. #558
    Mar 2014
    Vacaville, CA
    How well does the column fit within the rod end? Did you add some sort of bushing?
    I wouldn't be surprised if in a couple weeks you decide to make yourself a new frame out of thinner chrome-moly and build a diet 717 instead.
  39. #559
    Las Vegas, USA
    Quote Originally Posted by Boog View Post
    It needed a shim. Two 0.008" shims or my method of one 0.016" shim locked in place between the two shaft collars.
  40. #560
    Mar 2014
    Vacaville, CA
    Very cool.
