0
0
ok so driver side is on and looks good. After many attempts at tweaking the fit of the passenger side I came to the conclusion that the passenger caliper is different from the driver caliper. I will try to attach a pic that shows the difference in the cutout of the caliper where the rotor exits the caliper. You can see that there is a cutout on the driver side that does not exist on the passenger side. The fact that the passenger side caliper is not cut out the same way doesn't give me enough clearance to center the rotor between the pads. If I shim to center the rotor between the brake pads, the top right corner of the caliper comes too close to interfering with the rotor. If I shim to center the rotor in the caliper itself (and not the pads) the outer pad rubs the rotor due to the amount I have to bump the caliper out to avoid the upper right corner of the caliper opening. I am assuming this caliper opening should be cut out in the same manner that the driver side one is. Planning on calling FF on Monday to get some advice.
