Has anyone successfully incorporated ABS into their build? I'm in process of stripping my donor car (2002 WRX wagon) and wondering if I should bother. I have seen in these forums that some people are including them in the build but I haven't heard about any testing or results. It doesn't appear to be that difficult just somewhat time consuming but is it worth the effort? If anyone did choose to use it I'm curious to what was used for a proportioning valve (new, stock, both?). I was considering installing a switch so that I could use the feature or leave it off. I have heard that the 2002 ABS system was a little quirky and that Subaru made an update to the program, I'm not sure how to determine if I need to update the firmware or not. Where as I will not receive my 818 till late next year I haven't started a build thread yet. I can't tell you how much this forum helps, a big thanks to you pioneers for sharing so much info it is very much appreciated.
