I haven't had an opportunity to hook up the gas pedal yet. I want to get the cable mounted to the firewall before bolting up the gas pedal.
Alternator turned out ok. I painted the front cover and just cleaned the rear half. If I let myself get caught up in making every single part look perfect then I'll never get to drive it.
The engine assembly is slowly coming back together. The coolant tubes are mostly re-installed. I've come across a few things I need to continue putting the engine back together.
The intake manifold mounting bolts have been massaged to play nicely with the TGV deletes.
This week I did decide to bite the bullet and have Brian at iWire build me a custom harness. His work is very impressive and I'm looking forward to seeing the final product. It'll save me a lot of time in getting to go kart stage as well as clean up the install. 55 pounds of harness have already been shipped out. Looking forward to see what it weighs when it comes back.
