Results 1 to 4 of 4
Thread: oil pressure sending unit installation on efi 302
    Jul 2014
    Question oil pressure sending unit installation on efi 302
    I was wondering if auto meter oil pressure sending unit can be installed on oil filter adapter included with relocation kit.....is stock pressure sending unit necessary for computer in efi engine or can I simply eliminate it?
    Help is greatly appreciated.
    Colorado Springs
    Yes, you can drill and tap a hole in the block adapter or filter adapter for the sending unit. Make sure it's tapped in after the filter. The part supplied by FFR is cast aluminum. Be careful when tapping it, as it can crack.
    I think the only thing the computer uses the factory sender for is to run the factory oil pressure gauge.
    .boB "Iron Man"
    NASA Rocky Mountain, TTU #42, HPDE Instructor - Retired 10/24
    www.RacingTheExocet.com
    Jul 2014
    Thank You for advice Bob I will connect to filter re-locator
    Just remove the stock one in the block, and install the Auto Meter one.
