Results 1 to 5 of 5
Thread: Dimensions of subie tranny behind the axles
    May 2013
    Colombia
    Hi guys,
    I'm not going to be using the subie transaxle so I was wondering if someone with one lying around would be so and measure it for me? I'm playing with the idea of fitting either a boxter or a sequential tranny in there. The measurement I need is how much space there is behind the center of the axles, at the tranny flange to the end of the tranny.
    Speedy G
    Nov 2012
    Medina, OH
    Transmission mounting surface to the body (my body isn't on so I am eyeballing based on stock transmission shift bracket to body reported clearance issues. You likely have a little bit more space) is roughly 30-1/2". The axles are 6 to 6-1/2" back from the flange with the axles leaving the transmission closer to 6-1/2" and reaching the wheels 6" back. The axles angle forward as they go to the wheels. So figure 5-1/2" to 6-1/2" a safe range for axle shafts aft of the transmission mounting plate. The body of the Subaru transmission is about 26-1/2." The remaining 4" being space for the shift linkage stuff. I hope that helps your planning.
    Rich
    Canada
    If you're going to use a boxster tranny, why not throw in the Porsche flat-6 too?
    Nov 2012
    Medina, OH
    Oh the audio track alone would make that worth it!
    Rich
    May 2013
    Colombia
    Thanks Goldwing! I think that should do it. I didn't realize they were that long.
    Like someone said in Eric's 818e thread, unfortunately mine will sound like a big sewing machine. Maybe I'll pull a BMW trick and use the stereo so I can hear an engine sound from inside the car. Actually I'm the one that originally wanted to put a VR6 in there to make it sound better. What I'm going for now is sub-11 s 1/4 mile on batteries. More details soon.
    Speedy G
