Page 8 of 54 FirstFirst ... 67891018 ... LastLast
Results 281 to 320 of 2134
Thread: Plavan's 818R Build Thread
  1. #281
    Wayne Presley's Avatar
    Enterprise Alabama
  2. #282
    Clovis, Ca
    Quote Originally Posted by Rasmus View Post
    Links to the SFI stuff for side impacts? What's it called?
    https://www.pegasusautoracing.com/pr...p?Product=2396
    They also have 3/8" and 1/2"
    Thanks- Chad
  3. #283
    fasterer and furiouser
    Aug 2012
    Long Island
    For some foam, that is pretty pricey. Just fill the doors with packing peanuts... If you ever get hit it will look like the 4th of July. #kidding
  4. #284
    Clovis, Ca
    To keep the fireworks to a minimum.... Haha.
    I ordered the Fuel Safe cell. I did get the 17 gallon cell. The dimensions will fit nicely in the passenger area. I went the with Walbro in tank pump, and collector (a must), and the aluminum can upgrade. I also had them cut the foam so I can add a fuel level sender at a later date.
    I also was playing around with the 3D printer. I made another emblem for someone on another thread in the Body forum. However, I am leaning towards this one now for my car. Porsche font 818R. Just a rough print for sizing. I kinda like it.
    Thanks- Chad
  5. #285
    Las Vegas, USA
    I saw that thread, with the STi-ish logo. I'm loving the simplicity of yours though. The font's just to my liking. Does the font have a name or is it just "Porsche"?
  6. #286
    Clovis, Ca
    Thanks. Yes- just google Porsche font. Some don't look quite right though.
    Thanks- Chad
  7. #287
    Las Vegas, USA
    The FFR bracket needs to be designed better, period.
    I will also brace it with an additional, removable bracket tying into the main pedal structure. It will make it sturdier for my lead foot.
    The next step is to design a adjustable throttle stop. I may go with a simple long bolt, with a double nut for adjustment attached to firewall.
    Chad. Do you have a picture of the bracket you made to stop the pedal plate from flexing? What'd you do for a pedal stop?
    How thick's your spacer? I was thinking 1" - 1.125" would just about do it.
  8. #288
    Clovis, Ca
    Look a few posts down from that picture and I have the spacer length.... I think 20mm IIRC. Look for the bird$hit quick welds also a few posts down for the bracket
    I have not made a throttle stop yet. That's going to be soon since I'm about ready to start this ***** up in a few weeks. I'll probably 3D print something then bolt it to the firewall.
    Thanks- Chad
  9. #289
    Las Vegas, USA
    [/URL]
    Found it. Thanks.
  10. #290
    QC, Canada
    Those lateral links just kick ***, sick as hell.
    Tnx for the throttle pedal ideas and issues, I'll keep that in mind and also will fab my pedal stop as I don't have the OEM one.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  11. #291
    Clovis, Ca
    So I started on the part I really dreaded. The windshield surround/cowl. You 818S guys have it easy. There are no 3 dimensional roll cage bars going everywhere. We get the same part as you 818S guys, then we need to hack it up so it hopefully fits (And looks presentable in the process.) No template is included, so I suggest playing Tetris for an hour before you begin cutting and measuring.
    I have to admit, it was not as bad as I thought. I just took my time. I made good measurements, cut smaller/shorter than needed and checked fit.... then repeat. Always make sure to have it centered, and only make one cut at a time. I used the Harbor Freight electric body saw with great results (I may be biased).
    I also have the brake/clutch fluid reservoir relocation kit. This will really clean up the look on 818R's and also limit the cuts needed.
    I may have to move it back a tad, but I will wait until I start messing with the bodywork more. If I have to move it back an inch, the additional cutting will be minimal. This would only be required to get more "meat" for the rear hood pin install.
    But here it is- I even added the dash, and R shorty windshield. You cant get the proper curve with just the two clamps I was using on the windshield- but by hand it looks great.
    Thanks- Chad
  12. #292
    Clovis, Ca
    With hood mock up-
    Thanks- Chad
  13. #293
    Clovis, Ca
    Am I supposed to flip this aluminum panel "Dash Close off" #80546 so it is angled "up" instead the way it is now? It does not look right to me, but I have not tried it the other way yet.
    Thanks- Chad
  14. #294
    Enterprise Alabama
    Angles up into the crease of the suround
  15. #295
    Clovis, Ca
    Thanks Wayne. That makes more sense. Garage is too hot to mess with it right now.
    Thanks- Chad
  16. #296
    Enterprise Alabama
    Put bulb seal on it
  17. #297
    Clovis, Ca
    I have to admit- I have not looked at the manual in a long time since it not that great for the R. I just popped it open... and there it was- a segment on the question I asked about dash piece... lol Thanks again Wayne
    Thanks- Chad
  18. #298
    Clovis, Ca
    Guess what showed up today when I came home for lunch? I'm getting excited now.
    Thanks- Chad
  19. #299
    Tazio Nuvolari wannabe
    south-central CT
    Congratulations! It's looking like a race car.
    What is the size and dimensions of the cell? I can't find what you decided on.
  20. #300
    Clovis, Ca
    Info-
    Complete Pro Cell, PC117
    Complete 17 gallon Pro Cell with steel can, bladder, safety foam baffling, SF6X10E fill plate and fuel pick up assembly. Outside can dimensions 20.125" x 17.125" x 12.75"
    I have upgraded to an aluminum can, race collector, internal fuel pump, pre cut sender area foam (so I can add a sender later easily) fuel pump harness.
    Thanks- Chad
  21. #301
    Clovis, Ca
    Just got the email I have been waiting for. One of the first Gen 2 vacuumed formed Carbon Fiber 818R race splitters coming my way. I'll post pictures when I get it.
    Thanks- Chad
  22. #302
    QC, Canada
    What does it do better?
  23. #303
    Clovis, Ca
    Lets just say FFR had someone else make it this time....
    Thanks- Chad
  24. #304
    NoVA
    Excellent, looking forward to the improved pieces. I'm using the R carbon aero parts on my S.
  25. #305
    Clovis, Ca
    The rear bumper is done. I just need to take all my mesh/frame bits to get powder coated.
    Now on to the front bumper/headlights
    Thanks- Chad
  26. #306
    Clovis, Ca
    Moving on to the exhaust. I bought an Invidia Divorced/ catless down pipe ($275ish). It's all an 818R needs. The pipe in stock form hits the 1" square tubing on the passenger side. Its an easy fix for a Muffler shop. I would have them cut it, reweld to my designated exit location once I get the body on. I plan on the exhaust going out the passenger side.
    Thanks- Chad
  27. #307
    Clovis, Ca
    The new Gen2 818R front carbon fiber race splitter was just was delivered. It looks really good. Just like the APR wing.
    I'm making a template of it now. I want to get a Tegris one made if this one ever breaks- 3.5 inch ride height, and race curbs take their toll after awhile.
    Backside-
    Thanks- Chad
  28. #308
    Edmonton, Alberta
    Very jealous of that splitter! Did it cost more than the Gen 1?
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  29. #309
    Aug 2013
    Santa Rosa CA
    Hey Chad I noticed that neither you or Brandon have cut out the rear of your cars as much as the FFR car. Any reason or just cosmetics.
  30. #310
    Clovis, Ca
    Mine was on back order- but I requested to get the Gen 2 version after seeing the rear "Carbon Fiber" diffuser. So no it did not cost me anything extra. In fact, I think this was the last piece missing from my kit.
    Thanks- Chad
  31. #311
    Clovis, Ca
    Quote Originally Posted by D Clary View Post
    I can't speak for Brandon, but I'm worried about the structural integrity of the fiberglass by making all those cuts. It would really weaken it. I may make them later, but one tap in the back and the bumper would be toast.
    Thanks- Chad
  32. #312
    QC, Canada
    Do you need to wet sand the splitter still?
  33. #313
    Clovis, Ca
    Nope- the front side looks like the APR wing and properly finished.
    Now the rear diffuser I have from them........ It's just fiberglass that they sell as carbon fiber.
    Thanks- Chad
  34. #314
    QC, Canada
    Darn, I want a Gen2 for free.
  35. #315
    Yea no kidding...I think all of us that purchased what was advertised as "carbon fiber" pieces should have the option to swap it out.
    Looks great man, keep it up!
  36. #316
    NoVA
    That's a significant improvement over the gen I pieces. Looking much better.
  37. #317
    Clovis, Ca
    Since I have this whole week off, I'm hoping to get alot done on the car. The completed harness from Brian from IWire should be here tomorrow. I'm looking forward to it.
    I designed a new radiator/coolant tank overflow bracket for the front- Its printing right now. This will allow me to mount the stock WRX overflow tank behind the radiator similar to the stock set up, but one peice with my radiator brackets I printed earlier. I'll post a picture when done.
    It will be printed in black ABS (Red is easier to see when building in the software)
    I'm picking up the mesh/frames/diffusers from the powdercoater today also.
    Front UCA's:
    I cut 1/4" off each of the rear stubs. I was able to get -2.9 degree camber without cutting the long front one. You will only be able to use one Locknut on one side. Once I get the final alignment done, I will be using blue loctite for added piece of mind. I plan on cutting the longer front stub today by a half inch to get me over the -3 mark.
    Thanks- Chad
  38. #318
    QC, Canada
    It must be fun to design your own part and see it printing at home. No need to pay big bucks. Is the 3D printer a great investment yet?
    How much camber you were able to get without cutting that quarter of an inch?
  39. #319
    Clovis, Ca
    The 3D printer is awesome. Pricey, yes. Not sure I would buy it just for the 818R- but I use it for other things too. I bought the printer that prints in ABS plastic instead of the PLA plastic. ABS is much more durable than PLA. Its better for what I am doing.
    One thing to keep in mind is that 3D printing is alot of trial and error- its not as easy as making an item, then printing it. There are alot of variables like nozzle temp, build plate temp etc. This part will take 5 hours to print because I'm doing 100% infill (Solid). Prototypes I do 10% fill (hollow/ honeycombed inside) to save time and plastic.
    30% of the time there are printing failures- Print comes of build plate in middle of print, then you have a plastic glob. etc- So it takes time to get things right. It's not like sending a document to your inkjet for a print.
    The camber was minimal (R ride height) without cutting, I think it was only -.5 to -1 fully cranked down.
    Thanks- Chad
  40. #320
    QC, Canada
    Yeah I read a bit on those printers. Lots of configuration and trial and error. I didn't know about the failures. I guess it's too pricey for one car, for me.
    BTW, sending to your inkjet can also be a pain and yield to failures. lolllll
    What camber FFR recommends for the R?
    For the S, it's -0.5 to -0.75, so I guess me I'll be ok and won't need to cut the UCAs.
