Got an idea in my head to build my own bump-steer correction kit. Apparently, the 818 bumps steers when you install the suspension in "R" ride height.
After days of thought on the imperial vs metric debate, I decided to go with imperial size rod ends. Two reasons. 1. The majority of the suspension in the rear will run imperial rod ends and bolts. 2. Price. M16 rod ends run about $65 and 5/8" rod ends run $20 for similar ratings. Next you get in the price of Metric Grade 10.9 hardware vs Imperial Grade 8. Anyway, I cut the end off some old OEM steering rod ends. Drilled and tapped them for 5/8"-18.
Notice the spacers. FFR's recommendation to correct the bump-steer is to space the rod end's 2 7/16" down from the steering arm. Or 2 13/16" from bottom of steering arm to center of pivot point. I, intentionally, included a 0.128" washer and cut my main spacer short. Just in case I need to adjust something in the future by running thinner washer, no washer, or more washer.
Drilling out the steering arms to accept 5/8" bolts. Ridiculousness.
The full set of hardware that went into it all. I found some nice rod end boots from Jegs. The stainless steel washers in the boots are 0.047" thick. So my full spacer kit is ---> 0.128" washer ---> 2.263" big spacer with bevel for range of motion ---> 0.047" stainless steel washer with boot.
Installed.
Other side.
What side goes where? The rounded side or the sharp side toward the work?
