Thread: OK, Next problem - Throttle Cable
    Groton MA
    I installed the throttle pedal today then went to put in the cable but the little lead ball at the end of the cable falls right through the hole in the pedal arm. I called FF and they said it should fit without anything but the CAD picture shows some sort of spacer/washer.
    What am I missing?????/
    Wayne Presley's Avatar
    Enterprise Alabama
    There should be a plastic sleeve on the cable to snap into the throttle pedal.
    Groton MA
    There was no plastic sleeve that I found.
    I will have to call FF
    Quote Originally Posted by palomino View Post
    I think the plastic sleeve is off the donor. see picture below:
    Freeport, ME
    nope, comes on the new cable, too big to go through the hole, you have to drill extra large hole in firewall and use some sort of washer setup on firewall. I've seen updated instruuctions come through on one of the manual updates, I had to modify my own last summer when I did mine
    Dan
    fasterer and furiouser
    Aug 2012
    Long Island
    agreed, should be already installed on the cable, no way to install it after. chances are it cracked off during packing/transport.
