Page 8 of 24 FirstFirst ... 67891018 ... LastLast
Results 281 to 320 of 925
Thread: Brando's Newbie 818R Build Thread
  1. #281
    Kirkland, WA
    And those cars have a much better airflow through the IC...
    There is very little track data on this car and its hard to say how it will perform w/o an AWIC, if I lived in a warm/hot climate I might look into an AWIC or if the tracks were short and no chance to cool down the engine I might look into an AWIC but for now it will be a wait and see for a stock engine.
    Tony Nadalin
    2022 SOVREN Championship
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
  2. #282
    Irvine, Ca
    Nope, not running autoX and it never gets above 80 here and I run on tracks that have up to a mile straight, so the Subaru folks here have no issues with heat soak.
    I was reading the blue 818R was having major heat soak issues. Your comparing a FMIC to a TMIC. Might want to reconsider that one big T.
    Wow you got an appointment coming up that soon. Surprised that you got an appointment so soon. Who many sb100s are left do you know? Let me know how it goes. Getting ready to start making calls to the DMV soon.
    I will find out how many SB100's are left and let you know next Tuesday. Last year they didn't hit the 500 mark so i'm pretty confident they wont hit it this year.
    The DMV doesn't check the car itself they just go over paperwork and take your money. I believe they give you a 2 month hall pass to drive the car while you get the CHP and referee to pass the car.
    During those 2 months i'm going to try and get away with as much as I can. My thought is if i zip tie the lights and blinkers to the chassis and get my 5 point harness installed that i can drive it around without the body panels. That way I can iron out the kinks while keeping easy access to internals. Not to mention it sounds delightful.
  3. #283
    Irvine, Ca
    Oops, sorry it was my Evo that had the FMIC. Obviously the EJ has a TMIC but you know what i'm trying to get at.
    How's the harness working out for you?
  4. #284
    Aliso Viejo, CA
    Quote Originally Posted by Brando View Post
    Definitely go to San Clemente and talk to Guy. He knows the SB100 front and back. There's another lady there who is really good too.
  5. #285
    What tools are needed to tap a burp nipple into the radiator outlet? I know that this nipple is then attached to the outer small hose nipple on the turbo tank. What does one do with the other (inner) nipple on the tank? Do you just cap it off?
  6. #286
    Wayne Presley's Avatar
    Enterprise Alabama
    Quote Originally Posted by tmoretta View Post
    You need an 11/32" drill bit, 1/8 NPT tap to put in the nipple in the water outlet. The degas tank has 2 ports on the tank and one off the tank cap. One goes to the turbo, one to the nipple and the cap port goes to the recovery tank.
  7. #287
    Encinitas, CA
    Quote Originally Posted by ehansen007 View Post
    The DMV in SC? I might consider driving up there for my paperwork when the time comes rather than rolling the dice at the Vista DMV.
  8. #288
    Encinitas, CA
    Thanks Wayne, I'll be doing this soon, just ordered the tap off Amazon. Does it need to go on top of the outlet, or will it burp out air fine on the side?
    Maybe we should move this discussion to it's own thread, rather than clogging up Brandon's. I'm sure most builders will want to know about and perform this mod.
  9. #289
    Kirkland, WA
    You can also add a T filler neck between the pump and the hose, someone should be able to design a nice filler neck that will serve as a burper also
    Tony Nadalin
  10. #290
    Carrollton, Ga.
    Wayne - one question about your system: since the nipple is "open" all of the time, how is the system able to pressurize? I ask this contrasting this situation with a double-valve radiator cap and expansion tank- type setup. Is the static pressure of the "water column" of the coolant in the tank enough to offset the pressure?
    Thanks, Bill
  11. #291
    Thanks for the info Wayne. Are guys mounting the recovery tank near the engine then, or running a long hose forward and mounting the tank on the radiator as in the donor car?
  12. #292
    Irvine, Ca
    I went to the San Clemente DMV during lunch today and they were closed for construction.
    I think people are mounting the recovery in the rear. In my case I have an AWIC which has a 2nd radiator up front which required me to have the recovery up front where it was originally. I have not yet purchased a 2nd recovery for the rear so I am running a long hose from the degas to the front recovery. I do intend to add a second recovery in the rear for this soon however.
    If you don't have an AWIC your supposed to mount the recovery in the rear and plug off the front radiator and use the degas exclusively for overflow/recovery
    Quote Originally Posted by Bill Waters View Post
    The nipple runs to the degas tank which is still pressurized
  13. #293
    Enterprise Alabama
    Correct.
  14. #294
    Carrollton, Ga.
    So, then, the cap on the degas tank is a radiator-like pressure cap?
  15. #295
    Enterprise Alabama
    Yes it is
  16. #296
    Carrollton, Ga.
    Enterprise Alabama
    Another thing to consider since you are going to run the stock ECU is that the air temp sensor is in the MAF and ahead of the turbo and IC. The ECU has no way to know how well the IC is cooling the air charge. It's only safegard is the knock sensor which pulls timing and the car slows down. I brought an OBD II datalogger to the track testing to check the effectiveness I was surprised that the thermistor was just an ambient air temp.
    Sorry about the thread hijack Brando
  18. #298
    Irvine, Ca
    You know i don't care bro. Hijack away
  19. #299
    fasterer and furiouser
    Brandon, I picked up one of these so I can tweak my air to air intercooler.
    http://www.fastwrx.com/mavdiintega.html
  20. #300
    Mechie3's Avatar
    Is it bad to use two recovery tanks, one in the front on the radiator and one in the back on the fill tank?
    I ran my fitting/hose to the top. There's a nice square boss on the casting on my 06 pipe that gives extra meat for threads to grip and seal against. I used a 90deg fitting because the turbo inlet runs over this pipe.
    Zero Decibel Motorsports
  21. #301
    Enterprise Alabama
    Works just fine, the stock WRX uses the same two recovery lines that happen to go to one tank instead of two tanks.
  22. #302
    Irvine, Ca
    Brandon, I picked up one of these so I can tweak my air to air intercooler. http://www.fastwrx.com/mavdiintega.html
    That is slick.
    What kind of adjustments can you make on your intercooler?
  23. #303
    Enterprise Alabama
    Here is an 06-07 and a 02-05 tank. A goes to turbo, B goes to the new nipple and C goes to recovery tank.
  24. #304
    I will use it to make sure it is getting enough airflow... I know what deltas people are getting on the Grimmspeed TMIC on WRXs, so I'll be using that as a target to determine what sort of ducting/cutout and or fan is needed.
    I'll also be able to throw the stock tmic on there and get numbers to people who are using the FFR ducts/stock IC.
  25. #305
    Craig,
    You can get it trouble with 2 tanks.
    When hot it could dump coolant into tank A. When it cools it could suck out of tank B. Or vise versa.
    Best to run both overflow hoses to the bottom of the same tank.
    Encinitas, CA
    Thanks, Wayne. As they say a picture is worth a thousand words...
    Thanks Craig. That looks like a good location. Unfortunately, I just installed my Gimmick inlet, so now I have to go back and get it out of the way! If I had known about this last week...
  27. #307
    San Diego Ca 92106
    Thanks Wayne, that cleared up the confusion in my mind. ( at least on this question. LOL)
  28. #308
    Irvine, Ca
    That created question to the setup.
    I have a 1.3 bar radiator cap and a 1.1 bar degas cap. In that scenario isn't it safe to say the 1.1 will blow off first? If so does the 1.1 also suck back in first when the water cools?
    If yes to both then wouldn't it be safe to cap off the overflow nipple on the front 1.3 bar radiator cap?
  29. #309
    Suisun City, CA
    Best bet is to use the correct caps on each end. The OEM upper coolant reservoir cap vents and pulls a vacuum. The OEM radiator cap ONLY vents. It will not pull a vacuum when the system cools. IIRC, the radiator cap is also a higher pressure than the upper cap (18 lbs vs. 16 lbs).
    818S - #67 (SOLD IT!)
    Delivered: 18 November 2013
    Go Karted: 29 December 2013
    Finished: NEVER!
  30. #310
    Enterprise Alabama
    It will pull from the one with the recovery tank closest in height to it's respective cap as it take more suction to lift it from a lower level. So if you mount each recovery tank at the same height difference from their caps, they should draw at the same rate.
  31. #311
    Irvine, Ca
    Rear Hatch Body Pins too long
    It's hard to see in the picture, but the rear hatch panel body pins are an inch or so too high. I have adjusted them as low as possible
    What's the trick?
  32. #312
    818 builder
    Exeter R.I
    You have to either make brackets to set them lower or extend there threads
  33. #313
    Rhode Island
    "the rear hatch panel body pins are an inch or so too high. I have adjusted them as low as possible"
    I had the same problem last week. Either yourself or have somebody else as I did extend the threads on the pins close to the holes that go through the pins. Problem solved.
  34. #314
    Denver, CO
    Brandon, did you have to cut around the roll bar to fit the panel? what's up with the gap left under the bar? Is the cut off piece just get mounted there? thanks
  35. #315
    Irvine, Ca
    Quote Originally Posted by Doowop View Post
    The gap left under the "R" bar is "as is" and came from FFR as you see it. I looks fine in person, the picture seems to accent that gap more than real life does.
  36. #316
    Irvine, Ca
    ffr 818R Dynotest Dynapack 2004 EJ20 Tune 1
    284 HP & 269 lbft to the wheels.
    It's a whole new world driving the car now. The tires are putting the power down well. In a straight line they don't break loose even in 1st. Neck snapping quick. I LOVE IT!!
  37. #317
    Denver, CO
    which actually bring a point. On the Blue R, they have some Carbon fiber (or carbon fiber looking pieces) in that opening and also around the door edges and the other cut out like where the wing goes. Have you or any R owner thought about what to do there to make it prettier?
    Great numbers on the Dyno BTW!!
  38. #318
    Tazio Nuvolari wannabe
    south-central CT
    As an R owner, functional comes to mind. Pretty does nothing. Perhaps sexy could make it faster.
  39. #319
    Clovis, Ca
    Tape
    Thanks- Chad
  40. #320
    818 builder
    Exeter R.I
    Nice power man, I was so close to the dyno, actually was planned for yesterday and I was expecting 340whp, but now it's zero lol .
