Nice engine!!!!!
Nice engine!!!!!
"Scotty, give me all the TRACTION she's got!" Pictures of what I drive till 818R is finished
Track Car Journal on IWSTI (with build info)
I think the rack and spindles will be the first things tackled on my R. Nice work there. What finish is on the spindles?
I used POR 15 http://www.por15.com/BLACKCOTE_p_36.html as I use it on my challenge car and holds up very well
Tony Nadalin
2022 SOVREN Championship
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
When I went to source some bolts separately, I found that the metric ones were significantly harder to come by in the higher grades than SAE. Still, it would be a nice upgrade option...
I use Poe 15 or chassis saver brand, pretty much the same stuff
I ordered my Wilwood Brake Kits, I only have $2000 to spend so was going to order the black 12" front/rear kit from FFR but found the red 12" from Autoplicity for cheaper than what FFR wanted for the black. So the I went for the Wilwood 140-9193-DR and the 140-7006-DR where just a tad over $1800 shipped.
I also ordered my Mishimoto Aluminum Performance Radiator MMRAD-WRX-01 from AutoAnything for just under $250 shipped, so the savings on the brakes pretty much paid for the new radiator.
I'm going with the StopTech brake line kit (front and rear) for just under $100 shipped form AutoAnything.
Tony Nadalin
Autoplicity prices are hard to beat.
I just boxed up all my wire harness (big box 18x18x20) and sent all 49lbs of it off to a service to get it dieted into something I can use, this should be an experience
Tony Nadalin
One step closer
Tony Nadalin
Your bare frame looks so clean it almost looks powdercoated.![]()
Congrats on the new kit!
One comment about the Whiteline KTA109 rear trailing arms. I ran these for about 6 years on my daily driver wrx and they worked great but did end up rusting and seizing up eventually. So don't be afraid to coat them with WD40 or some sort of other rust inhibitor from time to time. Granted, your R probably won't see as much rain or snow as my daily driver did.
Good point.
Excellent point. FFR, are you listening? I think being a "World Class", "World Car" kit car maker would be of interest.
I sure hope so. Right on the first page of the 818 page:
"New Markets: It’s a global marketplace and the 818 is destined to bring the Factory Five experience to a whole new group of people, not just in the U.S., but all over the world. Designed to be affordable to build, right or left-hand drive capable, and with components that are readily available in other countries, the 818 is Factory Five’s first “World Car”. But it’s not just exporting the FFR experience to other countries… at the same time we are also inviting an entire new generation of Subaru-knowledgeable car-builders to the Factory Five community."
https://www.factoryfive.com/kits/project-818/
How's SAE going to work in that program?
Sorry for the thread hijack.....back to the real subject of the build now.
While I think metric hardware would be a very nice thing to do, they do SHIP the SAE hardware with the kit, so it's not like those in foreign countries would need to go hunting for them...
So then you would just need to buy a new set of tools.
818 SRX - #91
Arrived 01/02/2014
First Start 10/31/2016
First Drive 05/22/2017
Registered 10/25/2019 BRAP818
The Wilwood brake kits (front and rear) came from Autoplicity today, all intact and great price, saved like $500 over FFR price.
Engine/transmission on the way, JDM EJ207v7 and JDM 5sp (TY754VBBAA) with 4.444 final drive.
So still have to get new clutch/pressure plate and flywheel and timing belt kit w/water pump, looking at GATES Part # TCKWP328A {#WPK43513} 7 Components (1 Belt, 1 Hydraulic Tensioner, 4 Idlers, 1 Water Pump) PowerGrip Premium OE Timing Belt Component Kit W/Water Pump
Tony Nadalin
It probably won't make any difference to how your stock engine cools, but the Subaru water pump PN 21111AA026 performs better than the Gates pump or others with the "open paddle wheel" design as is the pump on the right in the picture.
Tony Nadalin
Yes. This may be very helpful to you, as an EJ207 engine owner. Ankur's Garage Part number Compendium.
I thought I knew a lot about engines till I had an ah-ha moment about the oil. Please excuse me if I am saying something amateurish.
Oil circulating is like our blood circulating. Blood movement cools our body, more-so than sweat. Oil cooling is just as important as water to me as a racer. It's amazing the temperature correlation between the two that I'm seeing. One helps the other.
Back some months ago or more we covered this somewhere on here lol, try to find it. Most JDM Engines and early Wrx usdms have the closed style pump which far better than the open fan style. My Version 8 ej207 has the closed style, I am 90 percent sure yours came with it, but obviously double check. If it got changed or you want a new one just get the old style with the part number provided. Also get the subie water pump gasket, the gates is paper crap.
Engine and transmission have been shipped
Tony Nadalin
My 2000lb per rack (8000lb total), Gladiator shelf came in today, so all set to accept the boxes when they deliver the 818
Tony Nadalin
The JDM ej207...ahhh, how sweet is that thing! Seems that only a handful of us are going with it, and that seems insane to me. This is the engine for an R-car. Nice pick Tony! But of course I'm biased as this is the engine I'm going with as well. ST2 power levels in stock trim...add e85, crank up the boost (swap injectors), and you've got ST1 levels. Man I love that engine!
Best,
-j
Ditto!! On board and I am the first to put it in an 818
Nice rack. You're gonna fill it up so fast.
Engine and transmission arrived today w/o damage, delivered into my garage
Tony Nadalin
Nice, looks familiar
OK, after seeing a co-workers oil pickup in his 07 Sti break, I have decided to go with an STi oil pan, Killer B pickup and baffle, I was on the fence about this but the damage caused was something I don't want to see and since this is a race car it will even go through worse conditions. So all that is now ordered.
Tony Nadalin
I hope all racers think an oil cooler is a necessity. I have one, a thermostatic valve, Accusump and a remote filter block on my STi. Nine quart total capacity.
Recently I removed the oil heater where I had perched my Canton oil filter bypass block.
I removed this:
Now, my oil lines have a straight shot towards the front and clear the header pipes a lot better. To do this you must block off the water lines or put a jumper hose between the nippled block plug and the water pump. You can also buy the plain Subaru block plug # 11021AA121. I chose to put a pipe plug where the nipple was and block off a very short length of the water pump return hose because I didn't want to pull the water pump off to drill and tap it. See last photo.
You will also need a short shaft, Subaru part #15018AA050, to replace the long one shown above.
Another option is to just use the outlet of the adapter block and return the oil to the top (by the dipstick) on a Moroso pan, or to the bottom, next to the drain hole, on a KillerB pan.
Recently I bought this cap, or block-off plate, to take oil out of the oil filter area or just close it off. Moroso adapter 23815 - Moroso Oil Filter Block Off Plate.
This lets you get the outlet line far away from the exhaust by going down first. The area is cleaner still. The outlet hose can drop straight down and away, clearing the headers by 2-1/2 inches. I'd probably still sleeve the oil line again. The return line can angle in from above and enter with a 45° or 90° and be well away from the headers. Where does the oil come out if you block it off? Good question. I think just below the oil pressure sensor on the main galley, but I haven't confirmed this yet.
This is similar, but they've left the filter in the stock location and used a piece of scrap metal tubing from cooling plumbing on top to create the bypass. Not that clean and the headers go right by there. That's also why I like to get the filter out of there; it's surrounded by red-hot pipes. One friend has already had an oil fire in this area while on the track.
Thanks for the write up, I use one on my Challenge car (I use the top Canton remote filter), mainly due to the fact that I originally had cooling problems and installed the oil cooler to help. I still have it but no longer have a cooling problem. I was going to look into the options for the Subaru (you now saved me some searching). I may or may not install something before I race, as I want to see what the temps are and then decide. Once again thanks!
Tony Nadalin
Engine on stand now
Removed the AC and PS
Transmission on shelf
Tony Nadalin
Car will be delivered tomorrow, would have been today but driver had reached his drive limits so will stay in Portland for the night.
Tony Nadalin
Car was delivered, took 2 hours to get it off the truck, what a disaster.
Trying to get the hoist to work
In my garage next to the challenge car
Tony Nadalin
That must have been a nightmare.
