Do you have the body completely fasten to the frame? And if so is the engine hitting the center of the hood or have you already cut the hole in the hood to give the necessary clearance. I have built 3 MkIVs with high school students and have found the only problem with the hood is usually the mounting of the hinges. That being said make sure you have put the hinges together correctly or fitting the hood will be impossible.
