Page 4 of 24 FirstFirst ... 2345614 ... LastLast
Results 121 to 160 of 925
Thread: Brando's Newbie 818R Build Thread
  1. #121
    Clovis, Ca
    Quote Originally Posted by Brando View Post
    I have been speaking to several well respected Subaru racers in the area and the input from them on the 5 x 100 wheel bearings seems the same. According to what they say, if the track has lines that run the car over the candy cane frequently then they are replacing their wheel bearings after 4-5 weekends of racing. Half the tracks in CA would fall within that category. In addition I plan on running hoosiers or slicks with spacers to offset so that will increase the strain on the bearings. Bottom line is I want to go with 5 x 114 wheel bearings.
    STI knuckles with pre-built 5 x 114 cost around $600 for all 4 corners which isn't much more than installing new 5 x 100's in my current hubs. Earlier in my build I had to replace my rear knuckles due to the fact the space between the holes for mounting to wilwood bracket was 3.75" where the correct WRX knuckles were 4.5" apart. I contacted wilwood and they claimed they didn't make a bracket for the STI hubs. So i source new rear hubs.
    What I am trying accomplish is have a rhobust 5 x 114 wheel bearings working with my 12" Wilwood brakes. There has to be a solution out there, does anyone have any idea how I can accomplish this?
    I understand the concern with the 5x100 wheel bearings on a heavy stock car, however I think the weight of the 818R will be the benefit for the bearing lasting much, much longer.
    Thanks- Chad
  2. #122
    Brandon, Call Jim Schenck @ FFR. I believe the Factory R is running Wilwoods...
  3. #123
    Wayne Presley's Avatar
    Enterprise Alabama
    Brandon, the wheel bearings are going to survive much, much longer since they are only carrying half the weight...
  4. #124
    Irvine, Ca
    Good stuff. I put the advice on this forum over all others. I will just do new stock bearings and call it a day. Thanks for the guidance
  5. #125
    Irvine, Ca
    Quote Originally Posted by Racebrewer View Post
    Hi Brando,
    How did the build quality of the arms seem?
    I extended the arms to their fullest and they get around 1 1/4" inch more reach. They are slightly heavier than the stock arms. In the closeup you can see the silver where I had to machine off about 1/8" inch from the black spacers. In my opinion the quality seems fine. Hope this helps
  6. #126
    Freeport, ME
    I have the same transverse arms but did not buy the trailing arms. I also had to machine the bushings for th transverse arms, I cut equal amts from each side. IIRC they were approx. .100 too wide
    Dan
  7. #127
    fasterer and furiouser
    LIC Motorsports machines sti front knuckles to fit WRX applications. you can get them with 5x100 hubs.
    I would see how fast your first set of bearings wears out before you drop the cash to swap them out.
    http://www.licmotorsports.com/produc...i_lic-03079012
  8. #128
    Kirkland, WA
    Agree, I just replaced all 4 spindles bearings, seals, etc. The rears were no fun to replace with the backing plate in the way. I expect that I will have no issues with the bearing for several years.
    Tony Nadalin
    2022 SOVREN Championship
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
  9. #129
    Suisun City, CA
    Would you happen to know the distance of the stock trailing arm, from the center of each bolt hole?
    818S - #67 (SOLD IT!)
    Delivered: 18 November 2013
    Go Karted: 29 December 2013
    Finished: NEVER!
  10. #130
    818 builder
    Exeter R.I
    In this setup the wrx bearings will last a lifetime.
  11. #131
    Irvine, Ca
    Quote Originally Posted by JeromeS13 View Post
    trailing arms measure 20 3/8" and lateral links 16 1/8"
  12. #132
    Suisun City, CA
    Finished: NEVER!
  13. #133
    Kirkland, WA
    I talked to John George and the one he was running at Watkins Glen had the 6 piston Willwoods.
    Tony Nadalin
  14. #134
    Clovis, Ca
    6 piston brakes will be overkill- You can save the cash for something else. I have 2 piston fronts on a heavier race car that is 40+ years old..... Never had a braking issue with correct fluid and pads.
    Thanks- Chad
  15. #135
    Irvine, Ca
    Either way the rear knuckle calipers need to be 4.5" between the holes. I wasn't able to find a solution to make the rear Wilwood caliper bracket work with a knuckle that will take a 5 x 114 (3.75" between holes) so I just opted to press new bearings in the rear. The 4 or 6 piston will still run into an issue if you get the rear STI knuckles to support 5 x 114.
    The solution I ended up going with is purchase new front knuckles with larger pre-pressed 5 x 100. I didn't want to locate & purchase 4 new axles to fit the 114's so this works well for me. Until a few days ago I wasn't aware they changed the front wheel bearing size after a certain year. It is my understanding these are more robust than the 2002 bearings I had from my donor but still 5 x 100. I will get more details unless someone else can elaborate further on this.
    Speaking of that POS...I think i need to take a moment to vent.
    For those of you building an R...I feel using a donor isn't the best way to go. I see many of the R builds are not going that route and you guys made a smart decision IMO. I think if you dig hard enough to find an ideal fit for the donor then perhaps it might be worth it if you wish to keep things stock. Not realistic especially for track use.
    What I have used at this point from my donor:
    • A peddle box that needed some bending to get to fit due to donor accident
    • Steering Rack (had to replace 1 tie rod end)
    • Axle pieces
    • A few nuts and bolts
    THATS IT!!
    Replacement List:
    • I tried to bleed my clutch last night but it shot a drop or 2 per compression. Trashed.
    • The master cylinder looked pretty tattered. The damage from the crash jacked up the bracket. Turns out you can't just order that bracket without the booster (that i could find). So i just ordered replacement brake & clutch cylinders
    • Tire & wheels are obvious replacements as are the seat(s)
    • Donor didn't come with a motor so I found one with $3k which supposedly had 45k mi. That's was for the motor, trans and they threw in a radiator for free.
    • My rear knuckles didn't work for the Wilwood setup and front i replaced for something with a slightly better bearings.
    • I'm assuming the Boyd tank that's coming my way wont need the donors fuel tank pieces
    • Some of my rear traverse/trailing arms were either bent or stripped/stuck together. Not to mention no ability to adjust them.
    • Crash damaged to the left front LCA, so went with 06 aluminum LCA's
    • Steering column i suppose I can use, but there was no key! I decided to purchase a second column. One will be stripped and painted and one will be street. Not sure how i will deal with the key situation being 1 column wont use it anyways
    • Wire harnes...I guess that's up to your patients level. I can't see myself spending weeks learning and dieting wires. I would blow a head gasket. I did still need 7 ends of the donor harness to splice into the TEC-S VCP sells so i suppose that might count for something.
    All in all I also chose poorly on my donor. Most of you found a much more usable WRX to dismantle.
    The time and energy spent stripping the donor probably wasn't a financially sound move...but it did help pass the time waiting for my kit and hacking away at it was a stress reliever
  16. #136
    Irvine, Ca
    Does anyone have a clear shot of how this piece goes in? I can't seem to find one.
    The rear body mount brace didn't line up, it was about 1/8" off. The only way I could secure it was by using a vice
    I did a test fit and will be shaving off at least 1/4" of the linkage today so i can find 2nd, 4th and reverse.
    This is 3rd
    Here is neutral
    What is the purpose of the aluminum in the scoop? Can this be omitted?
    Just for fun... a taste of months coming
    Just for fun. I treated myself and the family a preview of whats to come
  17. #137
    Freeport, ME
    that piece of aluminum is part of the IC ducting
    Dan
  18. #138
    818 builder
    Exeter R.I
    I scraped it and vented it, I am in not using the FFR supplied ducting, my plans are different. I also plan on using the r winshield down the road.
  19. #139
    Freeport, ME
    I'm not a fan of that ducting system either, please keep posting alternatives
    Dan
  20. #140
    I'm pretty sure that's not the IC aluminum, from what I can tell its a piece of front cockpit trim that doesn't fit the R... there should be another for the other side. You will need to make your own to fill the holes. Unless FFR sent me two sets, I have my IC aluminum wrapped up still. So I could be wrong.
  21. #141
    Irvine, Ca
    Shift Linkage
    After grinding the shift bracket as far as I was willing it was still binding against the rear fiberglass panel.
    I ended drilling out the center of the shift bracket so I could slide it a bit deeper then redrilled the pin hole. It worked great, I have plenty of room now.
  22. #142
    818 builder
    Exeter R.I
    That's what I did, great minds think alike .
  23. #143
    Freeport, ME
    FFR did send you two sets of IC ducting... the second came in that "upgrade box" that they sent to all of us! I wrote old on one set and revised on the other...
    Dan
  24. #144
    Irvine, Ca
    Upgrade box? Haven't received but good to know. No B.O. shipments received either but i'm being patient as it hasn't even been a month yet since delivery.
  25. #145
    brando,
    the update box showed up in late September.
    That was to fix early design changes or missing parts.
    I don't think you will be getting an update box
    bob
  26. #146
    818 builder
    Exeter R.I
    Yea I scraped them all, aluminum is worth some money ya know lol. I honestly can't see how there ducting works that great. I am going to use the quarter vent holes I cut out to go to a vent in front of the rear well that deflects the air towards the cooler. Maybe it works, maybe I will try something else, but I will be checking for cooler temp and airflow readings before, after, different idea etc.
  27. #147
    Freeport, ME
    mine is #17, PU 8/1/13, we got a box that included a bunch of stuff in September... no packing list :-( it did have a sheet of instructions for some of the stuff...
    for your B/O just keep calling, they don't really have a B/O process
    Dan
  28. #148
    Irvine, Ca
    I will start bugging FFR for B.O. items once I run out of things to do.
    My shift linkage is finally done and I'm really happy with the location. I installed the shifter in the stock location but it didn't feel right. I liked what longislandwrx did and positioned the shifter under the rails. It feels much better lower and more forward.
    I also installed the IC aluminum, gas pedal and removed unneeded aluminum from the steering column and painted it.
    Last edited by Brando; 02-11-2014 at 02:09 AM. Reason: Because I don't want people to know i misspelled the word pedal - hah
  29. #149
    Looks good man. Makes me want to put my tunnel in when I get home.
    I take it your are not going to drive this on the street, or are you just going to run a switch for turn signals?
    brando,
    I picked up my kit after this. I will check them when I get home tonight.
  30. #150
    Irvine, Ca
    Thanks for showing me the way.
    I have 2 steering columns. One stripped the other stock. I do intend to get this registered and drive on the street occasionally. It too sweet a car not to
  31. #151
    i'm pretty sure here's that piece, as seen on Eriks car.
  32. #152
    Red Bluff, Ca
    That looks like one of the pieces that close off the front fenderwell area of the car. There should be a left and a right one and they fasten to the frame just inside the front suspension.
  33. #153
    Irvine, Ca
    L.I.wrx have you found a spot for panel pair 80129 on your R?
    Drdracing i think you might be referring to 80174, i was looking for 80129. I have received a few pairs of panels that belong exclusively for the S. I think panel 35 & 36 are a few of those
    Tonight I tried my luck in applying vinyl 4d wrap on my interior dash. FAIL. That turned out harder than it looks i will leave it to the pros. In hindsight i should have snapped a picture it was good for a laugh
    On a better note I received my clutch & brake master cylinders today. I know might seem trivial but after upgrading the clutch, mating the trans,installing motor, bleeding lines then finally pressing on the clutch pedal and having the pressure plate release felt like a milestone achieved. Easily pleased I suppose but I am going to bed satisfied
  34. #154
    Irvine, Ca
    Took the Tire/Wheel plunge
    I'm ready for tires and wheels. I took the plunge today and went with the following
    Wheels: (from VCP)
    Enkei Kojin
    17x8 + 45 Front
    18x8.5 + 45 Rear
    Tires: (tirerack)
    Hoosiers R6
    225/40-17 Front heat cycled
    255/35-18 Rear heat cycled
  35. #155
    Brando, I understand the thrill of the small victories like your clutch pedal. It's all the little victories that make the build so much fun. Last night I identified and tagged a bunch of the wiring harness ends, thanks to Mechie3's work, and left the garage feeling successful. It's all about hundreds of little victories.
  36. #156
    nkw8181's Avatar
    Dallas, TX
    AZPete I'm right there with ya on the wiring. Following Mechie3's guide
    Nolan
  37. #157
    Brando... no it wont fit, just saving it for spare aluminum. the bar it attaches to is absent on the R. This is where it goes:
  38. #158
    Irvine, Ca
    Finally the mystery is solved. Well played thanks.
    I wanted to ask you another question. Are you planning to cut your center dash to fit the shifters custom location or going with a aluminum custom piece like Aloha818 did?
  39. #159
    I think I'm going to end up with a combination of both. I'm going to start by having one of the "legs" of the tunnel sheared off, and then cut a hole on top for the shifter. Then I can rivet the top and left side as one but have the right hand rivnuted so it can be unscrewed for access. I have to see how the fiberglass piece fits without the shifter piece. I may need to make an adapter up front.
  40. #160
    Since I have my transfer case disassembled and therefore access to the shifter, I am thinking of re-drilling the hole in the rod and cutting off atleast 1/2 inch of shaft.
