All,
I ordered and received the Wilwood 12"F/12"R brake kit from FFR. There is no problem with the fitment of the front kit, but I am having two problems with the rear kit fitment.
1) The holes on the rear caliper mounting brackets do not match the holes on the spindles
2) The hat doesn't fit over the parking brake shoes even when they are adjusted to minimum diameter
I am guessing that the problem is going to turn out that the rear spindles I have are not compatible, but I am hoping someone can tell me that with some authority. Maybe someone can provide a measurement of the spacing on the caliper mounting holes of their rear spindles. Maybe I am completely missing something! OK, get ready for the detailed presentation of the problem...
The spacing of the holes in the rear spindles is about 4.5". The spacing of the two sets of holes in the included Wilwood bracket (P/N 250-6982) are at least an inch wider than the holes in the spindles...
In regard to the rear hat not fitting, the wheel bolt pattern and the hat line up just fine...
...but the hat doesn't fit over the parking brake shoes...
...even when the parking brake is adjusted to minimum diameter.
I bought the set of front and rear spindles separate from a full donor car, so I am told they are from an '04 STi. I cannot be certain, and maybe that is where this fitment problem originates. I was under the impression that the '04 STi spindles were the same as the '04 WRX as they have the same bolt pattern that year. Please feel free to ask any other questions about this problem. I'm also soliciting both hard evidence and/or theories about what is wrong.
Thanks for viewing!
(Dont' worry. I will clean up the spindles once I know they will work!)
