I have been for some time considering buying the 818s kit and as I researched the boxer engine and it's size I became intrigued with its many similarities to the older 90s model eagle talon that I own. Mine has a turbocharged v4 mitubishi forged internals engine and has the same awd system which includes the belt transmission, a manual of course. Now the question that now presents itself is rather or not I could, with minor to moderate fabrication, fit this engine into the 818s. This would save me a great deal of money and considering the power of the mitubishi engine, it would also exhibit great performance gains. So if anyone has any advice or tips that you could give me or help me figure out if this is even a reasonable modification or if it is way too complicated to be worth it at the end, it would be greatly appreciated. It would also be helpful if anyone knew if I could used any part of the suspension of the eagle talon that would be otherwise needed from a donor subaru
But I asked myself before that if there were anything in it for me and it turned out there was quite a lot for me to take the risk. I'd like to know what's in it for you again? You really need to weigh in carefully the pros and cons, cuz there is a risk for sure and usually "risk" = "money" when the risk actually gets to life.
