in the process of setting up my 8.8 straight rear axle, i came across this spring between the gears i looked over and over at it and then thought is this a shipping clip to support the gears prior to axle install. (the complete kit axle 3.1 kit) ended up being a 3.73 in lieu of the 3.55 but thats another story.
well i looked at a blow up pic of the 8.8 in my chiltons and didn't see the spring clip,
so i decided well its not needed.
never saw the f5r manual blowup till about a month ago for reference page 246.
well it shows it as a preload spring............now the story starts.
is it needed????
well i decided to get to a 95 gt 8.8 thats been formatted for my neighbors street rod.
so yesterday i get the inspection plate off and BAMMMM the SOB's in there.
now i am bumming
pull the tires
pull the brakes ohhhhhhhhhhh the brakes.. can you say e-brake
to pull the axles, this e-brake from hell has decided not to be able to pull its tension out so i can put the clip in it to remove the cables i am close to cutting the freaking thing, i put a ratchet strap on it to pull back the tension and that won't do it, it works on the brakes as far as tension to the spring, so WTF.
i wasa hoping to get the damn clip in and button this rear-end up tonight a simple task, and the e-brake will not pull back to put the hold down clip in it.
i have done this on others so anyone know what is going on with this dumb mechanism.
always thought about a e-brake mod, but i just want to become road worthy.
any help woould be greatly appreciated, its time to hit it on another day with a better attitude.
Leo
