Results 1 to 4 of 4
Thread: E-brake build issue
    Novice builder
    Jan 2013
    Northern VA
    E-brake build issue
    has anyone else encountered an issue screwing the upper handle to the lower? I can only get the upper to screw in only about 3 threads, about 1/8" on. I have tried wd-40 and other lubricant, but it just stops as if it bottoming out... I don't want to strip the threads forcing it. Any thoughts?
    Thanks in advance for your help.
    Fubar94
    1970 Mach1
    2012 Boss 302
    Mk4 - under construction
    Jun 2012
    CrossRoads, Pa.
    Yes, I had the same problem, took the wire brush wheel on the bench grinder to it; polished it up, cleaned the threads, oiled the threads with regular motor oil then I was able to screw it all the way down. Previously I had the E-Brake parts powder coated so some of my problem was powder coating on the threads, worked ok after polishing threads.
    Nevin
    Carl
    I just finished the installation with a brake assembly I just received last week and it all went on fine.
    Did you by chance install both nylon white bushings? I went back and looked at my photos and the manual and I used only the 1 inch bushing.
    I also extended the Rachet to Handle Mount bracket to allow running the cables above the crossmember.
    The first photo shows the difference between the original and my bracket.
    Installed Parking Brake Assembly
    I utilized the Lokar cables which came with this nice adjustable transition piece
    I am using FFR Wilwood brakes, the parking brake is fully engaged at 3 clicks with plenty of room for adjustment as the cable stretches.
    Carl
    Novice builder
    Jan 2013
    Northern VA
    Thanks for the wire brush suggestion. That worked like a charm! This site community is the best!
    Fubar94
    1970 Mach1
    2012 Boss 302
