I was having a problem when I needed to bend my brake lines at an exact position to pass through an access hole that I had drilled.
I asked around and the answer I most often got was "You have to practice and once you get the hang of it, it's easy".
I'm a bit more scientific than that and came up with a way to get my bends exactly where I want them.
1. I purchased a tube bender. This is the one I use. It's cheap and available at any local auto parts store. The measurements I use here are for this bender, other benders may require different measurements.
2. Line up the brake line with the hole it must pass through and mark the location on the tube.
3. Measure and mark a spot 2.5" from the location marked in step #2.
4. Line up the mark from step #3 with the support on the tube bender. Make sure you use the correct mold for the size tube you are using.
5. Bend the tube, making sure it's tight with the contour of the tube bender.
6. Install the tube.
Note: Another useful tool is a pair of tube bending pliers. There are great for the small bends where the brake lines attach to the MC or flex lines.
I hope this helps someone.
Good Luck!!
