Thread: Need Pictures/Part Numbers of Aluminum Pieces
    Dec 2012
    Bakersfield California
    Does anyone have pictures of all the aluminum pieces for the Gen II GTM?
    I took all of my aluminum pieces to a powder coating shop and agreed with the shop owner that they would tag all the pieces with the part numbers. When I arrived at the shop to pick up the pieces they were all powder coated nicely but with no part number tags. The owner of the shop said he "forgot" to do it ....... thanks for that!!! Now I have a giant puzzle of parts with no part numbers. If I knew that was going to happen I would have taken pictures of all the parts before I took them to the powder coater.
    Anyway, I am hoping someone was smarter than me and took pictures of all the aluminum pieces regardless of what the powder coater may have told them.
    Dan
    You should just go through the assembly manual and mark them in reference to which page they are used. Not that bad a jigsaw puzzle. but then again I'm on my fourth GTM :-)
    Mad Scientist
    Sep 2011
    Meadow Vista, CA
    Quote Originally Posted by fact5racer View Post
    Looking forward to seeing the next one!
    GTM #253 In Process
    Central, FL
    X2.
    Each panel will only fit its intended spot so it will not be difficult to place as you go through the manual/build. The only item to be aware of is ensuring you have the correct panel overlapping the other when there is one.
    R/s
    Vidal
    CURRENT STATUS: Interior Rework and Bodywork.
    GenII GTM #331. Delivered (23/9/10)
    BUILD LOG AND WEBSITE:
    http://gtmbuild.weebly.com/ .
    South Carolina
    Show off...
    The Stig
    GTM #0081
    Dec 2012
    Thanks for the input. I'm a little less concerned now. If you are on your fourth one then maybe you could lend me one as a go by ....
    If you do have one you can't figure out, just post a pic, I'd be glad to help out.
