I have been going back and forth as to whether or not to add a glove box. Finally, I decided to try to build the door and if it turned out reasonably well then I would move forward with the glove box project. Below is a picture of my first attempt at building the door... I cut a total of six pieces of aluminum, so I actually have enough aluminum to make two more should this one not be satisfactory once completed.
I moved the fuse box to the right side of the car so there is not much room behind the dashboard where the glove box is located. The glove box will only be about an inch deep. A buddy of mine is going to 3D print the box itself. I looked at this project as the door and hinge being the difficult portion... if I can pull that off then my buddy can design the box to work with the door.
